Plasma cutter recommendations
/ Plasma cutter recommendations #61
Most of the Hypertherm machines going forward will come with an encapsulated 1 piece front end consumable. No more stack of parts to keep track of. Interesting idea that includes a chip to track wear and cuts. I've looked at these new parts but have no idea how it impacts the cost to use. Definitely a bold move.
/ Plasma cutter recommendations #62
Yeah and I bet that 1 piece will be more than the stack of parts, some of which will likely have been reusable on their older torch.
Maybe.
Makes sense from a convenience standpoint.
/ Plasma cutter recommendations #63
kind of surprised the infamous Mr. Colt did not help.
I'm going to guess that neither Jim the expert nor Samuel Colt the equalizer actually made an appearance.
I think I'd have gone with Sam; so much more intimidating than some technical expert.
/ Plasma cutter recommendations #65
Hypertherm AIR30 here ( the one with the built in compressor).
I like it and guess you’d call me a serious hobbyist.
Just wanted to jump in and let the people reading the thread know that I’ve recently seen advertising that Hypertherm has done some kind of technology upgrades on their latest versions than before.
I know nothing more about the supposed upgrades.
I just bought the same one. I suck at cutting right now, but hopefully I get things figured out a little better.
/ Plasma cutter recommendations #66
I'm no pro but I found 1) tilting my head as needed to watch the backside flame and adjust speed... 2) work on hand positioning... and dry run it a couple of times to get the 'muscle memory' if you will... 3) find a scrap or waste area to melt for a few practice inches to warm up before the game. :D
As I said, I'm no pro... probably a notch above novice, but that's my three cents (adjusted for inflation).
/ Plasma cutter recommendations #67
Unless it's a whack off, I always use a guide (template to make a cut) unless it's the CNC plasma table. Then the program controls the cut.
/ Plasma cutter recommendations #68
Yes guides and templates are your friend. I CA glued a few stainless magnets to one of my large metal framing squares. It makes a nice guide for straight and right angle cuts. The magnets lift the square off the surface and better supports the shield for drag cuts.
/ Plasma cutter recommendations #69
Hypertherm sounds like fun!
I have a specific task coming up and I'm not going to be a pro.
Maybe a pro-slacker.(y)
I've wanted one for ten years.....that was my first mistake, not getting one.
And with all the steel stuff I've made over the years.
Last week was the last straw, was cutting shapes with a jig-saw even..... in y2022.... for shame.
I ordered a Lotos 50A for $399, should arrive Wednesday.
/ Plasma cutter recommendations #70
Congrats... plasma cutting is so much more enjoyable.
/ Plasma cutter recommendations #71
Yup, the only thing more fun is when you automate them!
I have a 5x10 table at home with a hypertherm PM85 (just went down from a 105 due to no 3phase at the house) and a 6x12 at work with a Hypertherm Maxpro200.
Sent from my SM-G715U1 using TractorByNet mobile app
/ Plasma cutter recommendations #72
You had to go there... yep, jealous.
/ Plasma cutter recommendations #73
So, did the OP ever decide on what plasma cutter to buy?
/ Plasma cutter recommendations #74
Don't Know... Last seen Nov 19, 2018
/ Plasma cutter recommendations #75
I bought a HyperTherm 30XP. Even my 5 year old grandson can use it (well supervised...).
/ Plasma cutter recommendations #76
i bought a cheap cut 50 with a pilot arc. works great for me. I don't use it enough for a more expensive machine.
/ Plasma cutter recommendations #77
loads of fun!!!
Split a 3x6x.25 rect tube into channels
/ Plasma cutter recommendations #79
I have a 20 plus years old Hypertherm 900 it will pierce 1” and cut up to 1.25”. Needs lots of clean DRY air. Main thing is stay with a major brand for consumables to be available in the long term. I love the drag tip and it also has standard stand off tip. 20 plus years old and parts/consumables still available is a big selling point for me.
/ Plasma cutter recommendations #80
What are you making, Sodo?
Those are foundation brackets for a little shed for my lawn tractor that sits out in the weather, the poor deere....
Been intending to build it for 4 years.
All that..... then then it took just one day.
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64276)
KNOW BEFORE YOU...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
