etpm
- Joined
- Jun 30, 2021
- Messages
- 2,398
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
About 15 years ago I bought a Thermal Dynamics plasma cutter for use in my machine shop. It is, I think, an 85 amp machine. It will cut 3/4" steel at 10 inches per minute, 5/8" aluminum at the same speed. Once I had to reduce a big machine into pieces small enough for a scrapper to haul off. In that case I cut 3 inch thick cast iron. Not fast. And ugly cuts. But I did it and it was way faster than trying to use a portable band saw. My son and I were truly impressed that we could get the machine to do what it did.
I also know welders who use the Hypertherm machines. They love them. My Thermal Dynamics machine has been trouble free and is easy on consumables. Either of these machines bought used would probably be safe purchases as they both are quite reliable.
A couple years ago the start cartridge in my torch failed. The error code from the machine was ambiguous so I called my local Airgas, which sells Thermal Dynamics parts, and they told me I needed a complete new torch and lead assembly. I'm on the west coast and it was late in the day so the next day I called Thermal Dynamics Tech Support. They said it was the start cartridge. About one tenth the cost of the whole torch and lead assembly. That's what I call good customer support. Airgas seems to hire folks who know little about welding and welding machines, but Thermal Dynamics backs up their machines, even older ones, with good parts availability and good advice.
For casual use you may want to buy a Lotos machine. My brother has one of their TIG welders and it has worked well for him. But if you plan to use the thing a lot I would look at Hypertherm or Thermal Dynamics machines. Only because of my direct experience with one brand and the experience of people I trust using the other brand.
Eric
Eric
