johnnydel29
Hello -
I own a 2006 JD 2305 with about 1200hrs. I noticed it occasionally leaks antifreeze. The leak seems like it is coming from beneath the water pump. Or, it could be where the pump attaches to the engine (gasket).
The leak is not consistent. As I mentioned, it seems to happen when cold. When it leaks, it's minor. The antifreeze puddle is about the size of a quarter.
Has a similar situation ever happen to anyone? Is this leak a sign that the water pump is about to fail??
I am thinking of just going ahead and replacing the water pump. While I have it apart, besides the fan belt, pump, pump gasket, is there anything else I should consider replacing (I am thinking thermostat as well).
Thanks.
Thanks.
