New wood splitter hydraulic problem
   / New wood splitter hydraulic problem #11
MX
The adjustment is for the shift point pressure and turning screw clockwise will increase shift point pressure. Set to high this will stall your engine.
I don’t remember where the check is located but suspect under a different hex cap or plug.
This statement is what makes me think:
The unloader valve is allowing the initial low volume/high pressure flow to leak past and return to tank along with the high volume/low pressure oil. It eventually seals and will eventually allow the pressure to build up.
You can have 3KPSI but it doesn't necessarily mean you have any flow or the flow is going where it's supposed to.
Just a shot in the dark on on my end tho :)..............Mike
I may have wrote that wrong. When I first hit the lever to send the cylinder out the needle hardly moves until it hits the piece of wood then the pressure builds to around 600 lbs and sits there for what seems like an eternity, 7 to 10 seconds +/- depending on the rpm I'm running. then all of a sudden the pressure shoots up until it starts to split the log then it will drop back down and stay there unless it hits a hard spot then it will pop back up to what is needed to finish the splitting the log. Once the log has started to split the pressure up and down is normal operation while the log is being split. Most wood starts to split at around 1000 psi and with clean wood with no knots it will drop back to hi mode and finish the split. It's just that initial hesitation just before the shift to low that is the deal breaker.
MX
That's kind of what I was thinking so I guess I might try turning it CCW a little to lower the shift point and see what happens. I can't remember now but I don't think there is but one plug cap on the pump. That may be wrong and when I go out I'll look at it again.
   / New wood splitter hydraulic problem #14
Make sure you don't have an air leak on the suction side, as it will pull in air and foam up the fluid. That causes exactly the symptoms you describe. If you have a clear suction line you can spot this easily, otherwise look in the reservoir tank and see if the fluid has a lot of bubbles or foam.
When this happened to me, it was a leaky shaft seal on the pump that was allowing air to get sucked in. Very small leak but boy did it suck in a lot of air.
I have suspected air from the start and there is a possibility that my suction line may be the problem. It doesn't seem to show any leakage on the outside but it is an old piece of hose. I was going to put a new one on when I pipped it in but when I went to the hydraulic shop to buy one they wanted $47 a foot and I just couldn't see me paying that much for a piece of hose. I just ordered a 5' section from surplus center and it should be here next week so I'll try that and see what happens. That 5' piece with shipping was $43 and some change.
Well I finally got the 1" hose from surplus center and put it on the spliter but it does the same thing as when I had the 3/4" hoes on it. I also had a strainer in the line that I removed also so I'm pretty sure it's not starving for oil. I also checked to see how many caps were on the pump and there are two caps, one on the intake side and one on the output side. I was going to try an adjust the pressures but can't find out which one to adjust. I would think that the one on the intake side would be the one but didn't want to blow anything up in doing so. I know how dangerous hydraulics can be if all is not well in the system.
   / New wood splitter hydraulic problem #17
Where is the oil return back into the tank, relative to the top of the oil level?
In other words, does the oil return into the air space above the oil?
or
Does the return oil go into the submerged area below the top of the oil level?
If the return is into air,, you get splashing, and foaming,,
and air compression that takes, OH,, a guess,, 7 to 10 seconds,,,
The suction and return need to be FULLY submerged ALL the time.
How deep is the tank?
One of the functions of a suction strainer is to stop the type of air suction that you see when a bath tub is being emptied.
A bath tub is only emptying at 2 to 5 gallons per minute,, that is enough to suck air.
Your pump is trying to suck 16 gpm,, if air is the easiest thing to grab, the pump sucks in air.
   / New wood splitter hydraulic problem #18
or
I built the tank out of a piece of 10" schedule 40 iron pipe that is roughly 5' long. The oil level is higher than the pump inlet. The in/ out/ vent is all on one end of the pipe. The inlet pipe goes through the cover and extends 3/4 of the way to the back of the tank. I have a 45* fitting on the end that is turned downward and toward the back. I have a diverter plate about 6" from the end of the inlet pipe so as to keep the full force of the oil from just spraying into the tank. The oil exits the inlet tube at about the half way point of the tank and like I said it is somewhat turned down on a angle.
I have the suction line coming out of the tank as low as I could get it and there is probably about 1" off of the very bottom. There is about an inch air space at the top at the vent. I put right at 20 gal of oil in the tank and let it purge excess out of the vent to level it out. It may have spit out 1/2 gal or less and that's where it's been since I have been using it.
I know that this tank is probably a little small gal wise but my old splitter had only a 4 1/2 gal tank with a 11 gpm pump and I used that one for over 35 years with no problem. The oil never get's much over 100* even in the summer with hard use. I had thought about maybe adding another pipe tank over top of this one to get a little more volume because I was worried about the oil overheating but it never did in the time I have used it.
I had been worried about air in the oil so I put a section of clear line on the suction side to see what was going on but the oil always looked clear with no bubbles. You may be on to something with the bath tub thingy but it was doing the same thing with it in the line as it's doing now.
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52709)
2003 LEEBOY L150...
2020 CAT 308 (A53317)
60in Forks (A56857)
60in Forks (A56857)
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
