Should I trade my L2501
/ Should I trade my L2501 #1
TBone
LA (Lower Alabama)
Kubota L-2501 HST
I bought a new Kubota L2501HST in 2018 and use it strictly for bush hogging and a little loader work. I love this little tractor except for one thing. It does not have enough power to bush hog heavy vegetation. For loader work it's great and for light cutting it's ok. I know some will say I need to sharpen the cutter blades, adjust the angle of the cut, not cut so close, etc. I have sharpened the blades, I have adjusted the angle of the cut several times and I have no intention of leaving more than a couple of inches of vegetation behind after I run over it. The sad truth is the little tractor simply does not have enough power to do what I want it to do.
I wanted more power when I bought it but settled for the 25 hp because of the tier 4 emissions crap. Now I am wondering if I made a mistake and am considering trading it in for a L3901. I think the L3301 would be enough but if I take the plunge into the regen engines I'm gonna make sure I'm overpowered rather than underpowered. I often read of regen problems but don't have a good feel for their frequency. I understand that anything mechanical/electronic can experience occasional problems but if regen problems are rare rather than often I can live with it. I would be interested to hear from owners of Kubotas with tier 4 emission controls. Trouble free, occasional trouble or lots of trouble?
/ Should I trade my L2501 #2
One cheaper option to try if you need to cut heavy vegetation is to get a smaller cutter or just take a narrower bite with your current cutter.
/ Should I trade my L2501 #3
for sure you will appreciate the 60% more hp.
We have a L3301 and the regen is a non issue. Easy to tell when its happening because you can hear, feel, and see the light on the dash when regening. Worst case is it asks for more rpm (to create more heat) which is mostly a winter (-30c or colder) issue. REgen has been a non issue on all our stuff so far... fingers crossed.
A light on the dash tells you to increase RPM if needed.
Should be good for 3,000 hours or so of use before you need to worry about it.
/ Should I trade my L2501 #4
The market for used is so hot right now you could probably sell it for what you paid for it. More power is always fun, I regret not having my BX anymore because of some of the places I could take it (like driving it inside through double doors to move a gunsafe) but don't miss how slow it was.
/ Should I trade my L2501 #5
There are lots of low-hours medium sized used tractors in the 40-50 hp range. You can probably get top dollar for a one owner 2018 2501 on trade-in or just selling it outright. You can probably find a tractor like that (larger, more hp) without the DEF and Regen issues though a lot of people are paying more for them knowing all this.
How heavy a vegetation are we talking here? Clusters of 1" to 2" stuff can be as bad or worse than widely spread individual 3" saplings. What kind of hog? If most of your work is bush hogging, the implement matters a whole bunch. A truly HD cutter has a lot more rotational momentum weight than a lighter duty unit. Is your vegetation too much for a heavy duty flail with sheep's foot cast flails?
By the way, I do not own a Regen or DEF tractor but there is a lot of safety in numbers -- there are millions of them out there and the manufacturers have had lots of time to refine what is going on. I'd bet you can go to any size tractor WITH Def requirements and/or Regen periods and find they are not all that much grief.
/ Should I trade my L2501 #6
The PTO on your L2501 HST is rated at 19HP which is a bit underpowered if you're using a 60" brushog. Getting a smaller cutter as mentioned above is one solution and would certainly be cheaper than a new tractor. The minimum track width of the L2501 is 56" though so going smaller may not be the best idea. A lot would depend on how many acres you cut.
The upside if you do trade the 2501 is, you'll likely get most of what you paid in trade. The down side is the prices on new machines have gone way up, assuming you can even find one.
I have two Kubota tractors with regen and I can tell you from experience, it really is a non issue. If you plan on keeping the tractor beyond 3000 hours or so, it might become more of a problem.
/ Should I trade my L2501 #8
Maybe not wait so long between cuttings and take alot of stress off the cutter and the tractor...That's what I would do.
Thanks for the replies. My cutter is a 60" medium duty Land Pride. I like the width because it cuts out my tire tracks. Really don't want to move down to a 48" and don't want to make two passes instead of one. Used pre-tier4 tractors are scarce as hens teeth around here.
/ Should I trade my L2501 #10
As other have written (y) try lower range dryer condition see what happens.
/ Should I trade my L2501 #11
The traditional “rule of thumb” has been 5 pto hp for each foot of rotary cutter width. Meaning a 5’ cutter should be used on a tractor with a minimum 25 pto hp. I know that many people do quite well with a 5’ cutter on a L2501, but the OP is finding out that for their use, the rule of thumb is pretty good advice.
/ Should I trade my L2501 #12
This is my solution;
This is going on my L2501. We’re expecting 45-50 HP and 28-30 PTO. I’m expecting to have it installed in the next couple months.
Mike
/ Should I trade my L2501 #13
It’s a very common situation to see people selling the 2501 after realize by its so limited by low power. That’s why it’s the most common used tractor for sale
/ Should I trade my L2501 #15
Why not just buy a bigger tractor
Cost, DPF and a larger tractor won’t fit in my current garage (when the larger garage is built, I may reconsider). Plus, this tractor frame already supports 39HP, 45-50 ain’t much more.
Mike
/ Should I trade my L2501 #17
Mike
The pictured turbocharger is what you HOPE will be a solution.
I have been posting here since 2011. I wish you all the best, but I cannot recall ONE thread where adding a turbo to an engine not specifically set up for a turbo proved successful for the owner.
Get back to us when your solution is installed and you have 50 test hours on the force fed engine.
Mike, I am very interested in the outcome. Please post your results here. THANKS.
Me too.
/ Should I trade my L2501 #18
/ Should I trade my L2501 #19
I have been posting here since 2011. I wish you all the best but I cannot recall ONE thread where adding a turbo to an engine not specifically set up for a turbo proved successful for the owner.
Me too.
There’s no ‘hope’ here. The results will ‘prove’ the effectiveness of the turbo and turbo setup.
We already know the tractor frame will support 39HP and the turbo will produce a bit more, for a lot less money.
There are a couple successful L2501 turbo setups that have been running, without issue, for more than 50 hours.
It’s going to be a good project, I just need to find a local PTO dyno so we can verify our results.
Mike
/ Should I trade my L2501 #20
You might want to check out the new L3902 . It has some nice upgrades, and you could get R14 tires while you're at it.
2022 John Deere 317G Track Loader (A63109)
2022 John Deere...
2001 LEXUS RX300 SUV (A62130)
2001 LEXUS RX300...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 1990 Peterbilt 378 Tandem Axle Day Cab Truck, VIN # 1XPFDE9XXLD293381 (A61165)
INOP/NON-RUNNING...
UNUSED WOLVERINE JMR-22-8.5G SUSPENDED RIPPER (A62131)
UNUSED WOLVERINE...
