Should I trade my L2501
   / Should I trade my L2501 #21
This is my solution;
This is going on my L2501. We’re expecting 45-50 HP and 28-30 PTO. I’m expecting to have it installed in the next couple months.
Mike
I hope you take lots of pics of this project and start a separate tread. It should be cool.
   / Should I trade my L2501 #22
I will. Absolutely. There will be tons of information to share regarding the project.
Mike
   / Should I trade my L2501 #23
Your main problem is the hydrostatic drive. These tractors are built for convenience but you lose about 35% of your power just to run the transmission. Shuttle shift is actually quite convenient once you adapt and it's more reliable and quieter.
   / Should I trade my L2501 #24
You are probably right, the tractor may be under-powered for the job. 19 at pto may be too little. There is a price to pay in hp for the convenience of HST, and well as $$. But if you have 24.8 (Kubota L2501) engine, and the pto is 19, then the total loss for using the pto from the tractor is about 23%. And not all of that loss is transmission.
Anyway I never bought many large purchases hoping to reach the mininum required for projects or work. I always would like to have a little "too much" (if there is such a thing) for things like getting in soft fields or etc. The L3901 may be a better fit. The worse thing that can happen is that you purchase another tractor, and then discover that you wish you had gone with more HP.
It is a rare post that a person bought a tractor and said "I wish I had less hp."
As far as the regen process you seem to have already avoided, I have the L4701. NO PROBLEMS I am at 300 hours. There is so much discussion about that. You can write 100 posts saying it has been no problem, and there may some ACTUALs post of problems. Not a lot. Does it use more fuel. Maybe a little. But if you work while it regens, it makes little difference. The key to regen is heat. The tractor has to provide enough heat to burn particles.
Good Luck, hope you find a good solution to solve the problem.
Thanks. I would like to stay with the same size footprint on a more powerful tractor. I've got a bunch of trees on part of my property and the little L2501 gets around them like a dream. It's just the open part with heavy grass that the little engine just can't keep up.
   / Should I trade my L2501 #26
There’s no ‘hope’ here. The results will ‘prove’ the effectiveness of the turbo and turbo setup.
We already know the tractor frame will support 39HP and the turbo will produce a bit more, for a lot less money.
There are a couple successful L2501 turbo setups that have been running, without issue, for more than 50 hours.
It’s going to be a good project, I just need to find a local PTO dyno so we can verify our results.
Mike
Are you really sure that the engine and drive line components will support the boosted engine output?
Usually turbo'd engines have reduced compression ratio because of increased cylinder inflow temperatures or they have special coatings on the piston crown to take the higher peak gas temperatures. You realize that you will have to turn the fuel flow up also.
50 running hours will only prove you don't have an early engine death. Tractor engines are designed for 1000's of hours of dependable operation. I'd advise you consider more operating time before you declare success.
The proper way to design an engine and powertrain is to design it for a turbo and then de-rate for lower power models all the way to normally aspirated. The lower rated models will generally have greater durability. The alternative is upgrade the weak components as you uprate the engine. That means more parts inventory and additional manufacturing costs.
Unless you have a lot more info on the engine design details that are generally only privy to the engine manufacturer, make and break development programs are generally very costly.
Good luck on your endeavor.
   / Should I trade my L2501 #27
I've had the same issues as well. Cutting with a 5ft JD rotary cutter. Angling the cutter helped quite a bit (tail wheel is set to the lowest adjustment) and put brand new blades on it. Still struggles in thick, tall grass.
One thing I will do is cut some openings in the back of the cutter to help release the build up of cuttings. The tractor has enough power to cut or smash the grass, but not enough to keep cutting the build-up. Every time I bog down or the cutter clutch starts to slip, there is a huge clod of built up grass.
   / Should I trade my L2501 #28
Mike
Well, this is orange, and it's turbocharged. Seems to give it more power (if not sense)!
   / Should I trade my L2501 #30
I think the 60 inch is overtaxing the 25 HP a bit. I run a 48 behind a B 2301. Lots of power, and I cut close to the ground as well.
2003 GREAT DANE 96' X 42' FLATBED TRAILER (A57192)
2003 GREAT DANE...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
16001 (A55853)
16001 (A55853)
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A57192)
UNUSED IRANCH...
UNUSED FUTURE LASER LEVEL W/ TRIPOD (A57193)
UNUSED FUTURE...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
