Jrasband
- Joined
- Dec 31, 2021
- Messages
- 683
- Location
- Southwest VA
- Tractor
- Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
I am wondering if I can improve the shifting quality of this old tractor.
Shifting low,high, reverse lever is much easier than shifting the gear lever. foward reverse lever can be trickey to get into nuetral - sometimes I go back and forth from forward to reverse just trying to get into nuetral...
Shifting the gear lever can be so hard, it is impossible to shift while moving without stopping first. could this be a fluid problem, Is it possible there is dirt in the linkage? Hard to believe it came out of the factory like that.
I recently changed the hydralic fluid and filter, I replaced it with travler 46 as that is what was recommended. The fluid is very thick and I was wondering if putting something thinner in there would help.
I bled the system by removing a power steering hose and turning the wheel back and forth while running. Everything hydraulic seems to work good I think. The power steering does not work at idle - I have to give it a little throttle for it to work, is this normal?
Any ideas or advice are welcome.
