MX4800 - No trans pickup screen?
/ MX4800 - No trans pickup screen? #1
Michael In Tennessee
Gold Member
Niota, TN
Kubota MX4800HST
Getting ready to do 400 hour service. Based on suggested parts (only filters and oil) and looking at parts lists, I see no pickup screen. Correct? I'd hate to have to drain 12 gallons of UDT2 if I'm wrong. Pretty sure I'm right.
Other than cleanup, I'm done with the 400 hour service. $613 at the dealer for everything except motor oil and anti freeze. Another $100 for that. Rotella is hard to come by, BTW. My shop is a mess. I completely fumbled draining the antifreeze. Also trying to catch 12 gallons of trans oil is a slight challenge.
/ MX4800 - No trans pickup screen? #5
I use a 58 quart oil drain pan off Amazon for HST fluid. Works great.
/ MX4800 - No trans pickup screen? #6
Kubotas draw trans oil through the filter(s). Owner's book may say 11.6 gal but its more like 8 unless every pump, cylinder, filter and cooler is dry.
/ MX4800 - No trans pickup screen? #7
Fluid drain on either of my m9's is just shy of 15 gallons. I use an old junk truck aluminum fuel tank cut in 3rds. You pull the single drain plug and you'd swear it was an up side down oil gusher.
/ MX4800 - No trans pickup screen? #8
About 7 gallons on the too high side.
/ MX4800 - No trans pickup screen? #10
Don't use SUDT in either of my M's. I use Chevron All Weather THC Synthetic and have since the first change. I usually buy a 55 gallon drum of it. It's a tad more than SUDT but I have much better flowability in the cold winter weather than SUDT and it's orange, not clear. I get more than I need because I'm always loosing some when I change hydraulic couplers on my implements. Keeps the back end oiled.
PT Gravity Wagon (A64119)
PT Gravity Wagon...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
(1) 7.2-16 TIRE W/ 6 LUG RIM (A64280)
(1) 7.2-16 TIRE W/...
2019 JOHN DEERE XUV835R GATOR UTV (A64280)
2019 JOHN DEERE...
2005 TerraGator 8104 (A63688)
2005 TerraGator...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
