I have owned my last 2 wheel drive pickup
   / I have owned my last 2 wheel drive pickup #221
I've actually been reading up on the G80 quite a bit, as I would like to stop running my Colorado full time and make it more of an offroad truck for when I need it. Tonight instead of shifting into 4WD on the icy hill before my house I shut off the TC, to see if it would make the hill with just the rear differential locked. I made it about 2/3 of the way up the hill before the truck stopped. Shifting into 4WD I was able to go from a dead stop and continue up the hill. Had I been able to manually lock the rears it may have been different, as I would have been going faster than 20MPH while going up the hill.
Good experiment. (y)
   / I have owned my last 2 wheel drive pickup #222
10 years ago, Ford had the best hub set up automatic with manual over ride, just in case. My last Ford was an 08, I dont know what they have now.
It's the same. Our 2019 has Auto and Locked position on the hubs.
   / I have owned my last 2 wheel drive pickup #223
I believe the biggest reason they kick out at 20mph is do that if one tire breaks loose at higher speeds, the other won't take over and send you around in a circle. Kind if like that SUV you posted a couple of days ago.
Using a locker at significant speed would scare me. Getting moving is when a locker makes sense to me.
On the tires and 4 WD subject, last fall I loaded my wood trailer near a tree I was cutting up when the weather was good. Flat ground, but significant clay in it. When we needed to wean calves into that field, I needed to move the trailer out of there. With my luck, I needed to do it right after a rain. F250 with fairly aggressive tread, could not do it, all 4 wheels spinning, maybe moved the trailer 6". The only other thing I had at the time on that property was an old 2WD Massey 245 with good condition R1s. It moved the trailer without problem. Tire tread made that difference.
Not that I would buy a new 2 WD truck a 2 WD tractor.
   / I have owned my last 2 wheel drive pickup #226
2019 Ranger has a locker, kicks out at 20mph. Wish there was a way to increase to maybe 40mph...
   / I have owned my last 2 wheel drive pickup #228
What do you have, something which we can't get here?
Mitsubishi Triton GSR, 2WD, AWD, 4WD H&L, a large dial in front of the handbrake to select what you want, not all have the AWD just the GSR and the one below it.
I believe that it is not sold in the USA any longer but they are quite popular here, most utes (pickups) are 2 to 3.5 litre, of course we get the F's, RAM, GMC etc but they are not as popular.
   / I have owned my last 2 wheel drive pickup #229
I'd be happy with 30, as that's when my TC turns itself back on. Then again it would be helpful to increase THAT to 40... any faster thn that and it never activates anyways.
   / I have owned my last 2 wheel drive pickup #230
Us Yanks always think bigger is better. Often a disservice. In my Worldly travels (not down under yet) I always notice the use of midsize and mini size trucks is more popular. I know of 3, off the top of my head, 1 Ton, dually, crew cab, long bed, 4wd trucks around me that never haul anything or pull a trailer....
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
(7) Ten Hole 25 Inch Steel Rims (A57454)
(7) Ten Hole 25...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
Hydraulic Excavator Thumb (A57454)
Hydraulic...
