bobcat telehandler V417 wont go forward/back??
/ bobcat telehandler V417 wont go forward/back?? #1
versabob
Ontario, canada
Bobcat V417 telehandler
im new to this forum,hope someone out there can help i was skidding logs out with this v417 telehandler, went to switch it from 4wheel steer to 2 wheel and it just stopped, all hydraulics work, engine runs normally,got a red signal light on dash and a error code on code reader,contacted bobcat dealer, they were of no assistance,its a hydrostatic drive machine, has an electric shifter for FNR,ive checked all fuses related to drive,pulled wiring harness off and sprayed with contact cleaner,unit is 14 years old so im thinking maybe something in the shift lever broken or corroded, any thoughts are appreciated,just got this machine md year last year and have been happy with it so far
/ bobcat telehandler V417 wont go forward/back?? #2
My V417 is about the same age and have had very few problems with it🤞.
What code is it showing?
To display the service codes, press and hold the Work Lights button for three seconds. Use the Up and Down buttons to scroll if there are more codes.
Code is 98o98, I've not been able to find that code anywhere, I'm going to test shift lever wiring harness, I've sprayed female plug with contact cleaner, my uneducated guess is that this problem is related to shift lever,
My local bobcat dealer could not find that code,but, he did not sell me the v417 either,,I love the machine,just put new HD cans tires on her
/ bobcat telehandler V417 wont go forward/back?? #5
It won't start unless it is in neutral.
Put the lever in F or R and turn the key on, you should hear the beeper and the red FNR light on the dash should flash.
Ok,,will do,, I've already tried starting in both f and r, yes my fnr light comes on and beeps,,machine will start fine in neutral, revs freely,, just no forward reverse
The only other thing I could figure was brake-related, ie brake malfunction so it wont activate machines driveability
/ bobcat telehandler V417 wont go forward/back?? #8
That means the lever is working.
/ bobcat telehandler V417 wont go forward/back?? #9
/ bobcat telehandler V417 wont go forward/back?? #10
Does the red Park light go off when RPMs increase in F or R?
It could be the wires to the solenoids that control the flow to forward and reverse.
Code is displayed 98-98, red light did not go out when in f or r when rpms increased, I will try and find a service manual online to download as a pdf, I have no idea where those wires would go to drive solenoids,unless you access from under the machine,,its freezing rain here and about 25degreesf
Thankyou btw for your suggestions
hi xfaxman, im getting the codes 50-15 and 70-28 on my v417, still have a no-go forward or reverse, ive changed out the magnet on the rear spoolvalve at bottom of cab,magnet had failed and valve would not activate,i also had not power at the valve so have put in a layout wire line,now have power to it when parking brake switch deactivated, parking brake light has gone off but the fault light still illuminated and these two codes above showed up,i cant seem to find anything about inching control,any thoughts?the 70-28 code says brake pressure failure,any advice would be deeply appreciated as id really like to get the machine mobile again
/ bobcat telehandler V417 wont go forward/back?? #15
Have you tried all 3 steering mode positions to see if that affects it?
50-15 is Inching Control, out of range low.
70-28 is Brake Pressure, failure
Inching control is pressing the brake pedal slightly to decrease travel speed.
Pressing the pedal farther down applies the brakes.
If you did not get a service manual it is available from Bobcat to match your serial number: Service Manuals - Manuals and Instructions | Bobcat Company
Inching control is pressing brake pedal slightly to decrease travel speed.
thanks for your reply xfaxman, yes ive tried all three steering modes and no go in any of them,
i have downloaded a service manual but thus far cant find much on the inching control,
i may try to bleed the brake system(to address the 70-28 eror code) and make sure there isnt an air pocket in the system that is causing the issue, as well ill try and locate any brake pressure switch which may be faulty,
ive already replaced the magnet on the rear spool valve as it had failed or lost its magnetic properties, the valve now actuates but that hasnt fixed problem, ive released the brakes on front axles using the bolts and taking out spacers,to no avail.there is an inching button on dashboard,ill try actuating it and disengaging it,beyond that im stymied???? thanks for taking the time to respond.
/ bobcat telehandler V417 wont go forward/back?? #17
Mine does not have an inching button.
It does have a creep mode button, but that is not related to inching mode.
You are welcome, wish that I could solve your problem, but am too far away to use my multimeter on it!
of course you were right, mine has creep mode too, not inching, its been an interesting road, i know a lot more about telehandler now since trying to diagnose issue,there is no dealer near me for a 100 miles and that dealer has been shall we say,,,,non responsive.its frustrating because im convinced it is something electrical and my bobcat is old enought that i could have a bad ground or corroded wire somewhere in the wiring loom bundle,ill keep at it.cheers, and again my thanks for your kind responses
/ bobcat telehandler V417 wont go forward/back?? #19
You're welcome.
I think the Brake Pressure, failure code is what is keeping it from moving. The brakes spring applied and are released by hydraulic pressure.
Good luck and let us know what fixes it.
/ bobcat telehandler V417 wont go forward/back?? #20
Found this in my V417 pictures folder from May 23rd 2020.
Might help some future info seekers:
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
1996 INTERNATIONAL 4800 SPREADER TRUCK (A63291)
1996 INTERNATIONAL...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
Industrias America 435 (A64119)
Industrias America...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
