Getting the rear remotes on is the important part.  I would talk with Fit Right to see what they charge for cylinders and hoses. And talk with the dealer about what size cylinder and the cost of those you need.  You want to know the travel range so you can adjust the front and back blade of the Box Blade - meaning What length the top link cylinder should be. You can always add cylinders easily.  If you use the Box Blade for a while, you may find the length you prefer to use both blades and rippers.
Also, If you want a quick 3pt hitch, the length of the cylinders will change. Such as Pat's Quick Hitch. It will add about 3 or 4 inches to the top link.
