Citydude
Super Member
Valves are right side rear just below the cab. Control levers are right side of the loader control joy stick. The attachment doesn't show the control levers. They go where the slots are.
His stuff is that good and he is that knowledgeable.yikes! 34 week lead times. Wow that stinks lol.
Having said that RjCorazza, Bavarian and Citydude are right the factory stuff fits and looks better.
Another member here and myself have had issues with them. One valve has leak down. Not enough to be inoperable however I expected more from Kubota.
You might have more than one option. If you just ordered it, you may want to see if you can still get the order changed to include rear remotes from the factory. Of course the second option is to have the Kubota dealer do Kubota parts install.
And the third option maybe aftermarket parts. Then, you will wait until received. 34 weeks, I guess. But you will still be able to use your box blade during that time. Just have to manually adjust the blade to do what you want.
