Comfort Ride - new product by W.R. Long
   / Comfort Ride - new product by W.R. Long #61
Precision fork lift or boom work I close the valve to isolate the accumulators for OEM FEL work. Stops accumulator bounce.
95% of the time the valve is open and the soft ride is used. Traveling empty and transporting loads much smoother.
Transporting steel beams on forks every bounce is rough and can slide. Soft ride engaged much soother. Close valve to set steel, an example.
Handy to be able to operate valve from the operator station.
   / Comfort Ride - new product by W.R. Long #62
Great example on the use of the shut off valve.
One can also get fancy and get a solenoid operated shut off valve instead of the manual valve and just put a button on the joystick, like most factory setup works.
Something like this: Hydraforce 12 Volt DC NC Solenoid Valve SV10-22-0-N-00 | Solenoid Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
   / Comfort Ride - new product by W.R. Long #63
I still have the double ball valve, single throw that came with the Kubota soft ride kit. Looks expensive $$$. Suppose to be mounted on the FEL frame tower. Don’t know if it could be reached from the operator station easily. Wasn’t made for my loader so went a different route.
Did install a needle throttling valve in case I needed to fine tune. Not necessary so far.
   / Comfort Ride - new product by W.R. Long #64
Crystal clear Mr. Smokeydog. Thanks for your time providing the information.
   / Comfort Ride - new product by W.R. Long #65
You can even mount it at the back of the tractor. Just need to run a longer hose and connect it to the lifting line.
My valve is always open, I never close it. I can feel some movement when stacking bales.
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2012 Ford F-350 Crew Cab Knapheide Service Truck (A55852)
2012 Ford F-350...
377789 (A51573)
377789 (A51573)
