Deutz vs SAME vs SDF?
/ Deutz vs SAME vs SDF? #1
viktor675567
Massey
Hi. I can't understand the difference between deutz, same and sdf? there are deutz tractors with deutz, same and sdf engines, there same tractors with deutz, same and sdf engines, who make this SDF engines? are they more like deutz? or more like same? are there similarities between same and deutz engines? can someone explain :D ?
/ Deutz vs SAME vs SDF? #2
They have used "parts" back and forth, but they are mostly SAME and are good tractors.
The ONLY similarities between the Deutz and SAME air/oil cooled diesels are, they both are air/oil cooled and they are both diesels!
Both are excellent diesel engines.
SR
/ Deutz vs SAME vs SDF? #3
The SDF group includes SAME, Deutz, Lamborghini and Hurlimann tractors.
All the tractors made around the year 1999 and after, are pretty much the same across these brands with just a color change and maybe some minor changes. That's why you'll find a lot of similarities.
SR
thanks for replying, i was confused about the new water cooled engines, i have seen some smaller new deutz tractors using SAME 3.0L engine and SDF 3.0L engine, so are they referring to the same engine? or they are totally different engines?
/ Deutz vs SAME vs SDF? #5
SDF is Same Deutz Fahr.
I imagine it is the same engine, but we don't see a lot of them down here.
James
/ Deutz vs SAME vs SDF? #6
Don't pass by the SL&H insignia cast in every part of the Deutz Far tractors that come from that line.
Sub 50 HP are and produced in India IIRC. Now all Under the D-F brand Agro-Kid, Solaris, etc.
Dang, I looked on line for an image of the SL&H logo and did not find one.
Oh Well.
(Original Hurlimann Tractors are something entirely different. "The name has been changed to protect the innocent."
Suffered from "acquisition" .........
The small tractors make use of Mitsubishi 3 and four cylinder engines Some turbocharged.
Very early SL&H small tractors were offered with 3 cylinder air cool Deutz engines. (So my literature suggests)
/ Deutz vs SAME vs SDF? #7
If you were confused when starting this thread I imagine you are even more confused now !
Back in the 70-80-90’s there were lots of Deutz tractors sold in my area and most of them are still being used but these days there doesn’t seem to be many new Deutz tractors in my area and that’s probably mostly because the local dealer that used to sell them quit selling them but they still service a lot of Deutz tractors including complete overhauls . Sorry if your not a Facebook member you might not be able to view the link.
/ Deutz vs SAME vs SDF? #8
What's your definition of "small" tractors? Everyone that I've seen, if it said SLH on it, it was a SAME SLH diesel, if it had Deutz on it, it was basically a SAME, with a Deutz diesel.
And no, they are not the same design diesel. (other than they are both air/oil cooled)
SR
/ Deutz vs SAME vs SDF? #10
The Kid is a compact tractor, use to be built in Poland.
From there on up, they are farm tractors and were built by SLH, aka SAME.
SR
/ Deutz vs SAME vs SDF? #11
Same and Deutz were two different brands. Same originated in Italy and Deutz originated in Cologne, Germany. (Koeln-Deutz)
After a long history Deutz got aquired by Same. Their most successful engine was the air cooled system in different engine sizes.
Water cooled Deutz engines are still used in different applicatons nowadays. Not only in their inhouse brand tractors.
their water cooled diesels are very similar to MWM?
/ Deutz vs SAME vs SDF? #13
Can't confirm that. Don't know enough about both. I once read through the history of Deutz. There were a lots of aquisitions until they finally became SDF.
/ Deutz vs SAME vs SDF? #14
Just did a quick search for MWM. apparently CAT took them over.
/ Deutz vs SAME vs SDF? #15
I think NO, the SLH water cooled diesels are the air-cooled diesels with a water jacket. Liquid cooling is the only way they could reduce the noise the engine makes, and they had to meet noise standards some countries have.
SR
Hedge Posts (A65640)
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
Wooden Rocking Chair (A64127)
Wooden Rocking...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
30 Yard Roll Off Dumpster (A65579)
30 Yard Roll Off...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
