747driver
Its on the main panel breaker box. Only other option is for the power company to throw a cutoff switch at the transformer.If you need to kill the power going to the building how do you accomplish that?
After watching the video, it is indeed a poor job on the roofers part of not flashing the vent pipes ! Not sure i would ever recommend them to do roofing work !Sorry but gotta agree with dstig, I can't believe the roofers didn't consider properly flashing and sealing all protrusions as part of their responsibility?!? That's insane. Get a proper flashing boot over all your pipes asap. Seal the crap out of the flange to the metal roof with the proper adhesive. And then screw the flashing into the roof every single inch around the perimeter of the flange. Overkill is necessary for long term performance. Right now you have almost nothing.
Overszd, you hit the main/master breaker atop your panel. Why add a redundant switch? If you have to service the entire panel or feed, you go back to the transformer to disconnect (rarely ever needed).
There is a main disconnect on the meter box and every major breaker box has a main breaker. This is in rural Alberta.If you need to kill the power going to the building how do you accomplish that?
Again, it's always surprising to me how things are so different to control a common issue such as electrical. So you have to call the power company to kill power to your building? What if the building is on fire?Its on the main panel breaker box. Only other option is for the power company to throw a cutoff switch at the transformer.
Yes...only the power company can kill power to the building. That being said the fire department can take the meter out if needed ! Once the fire hits the breaker box it will kill the power ! I rarely ever see a disconnect between the meter and the main breaker box on residential buildings ,,,,,commercial yes.Again, it's always surprising to me how things are so different to control a common issue such as electrical. So you have to call the power company to kill power to your building? What if the building is on fire?
This guy really does great work ! I watch him alot...Not an expert, but ...
That would never fly here. Very interesting to see differences.Yes...only the power company can kill power to the building. That being said the fire department can take the meter out if needed ! Once the fire hits the breaker box it will kill the power ! I rarely ever see a disconnect between the meter and the main breaker box on residential buildings ,,,,,commercial yes.
