I have owned my last 2 wheel drive pickup
/ I have owned my last 2 wheel drive pickup #91
In the UP anyway once in a while you might run across a "camp beater" oversized rear tires, tire chains, 2wd, with a plow, about a pallet of CMU and any other junk one can find in the bed. So It must work good enough plowing a two track. These trucks never leave the woods.
/ I have owned my last 2 wheel drive pickup #92
Never has 4 wheel vehicle until I was 65 in 2017 when I bought 105K 2010 Subaru Forester. In 2018 bought 205K mileage F-150 4WD with the 10K tow package. Both have made believer out of me.
Now I was a 4WD EV. :)
/ I have owned my last 2 wheel drive pickup #93
The ONLY place I can think of where 2WD might equal or slightly better 4WD is on really slippery ice BUT, the 2WD would have to have CHAINS on it and at least 1000lbs in the bed.
The chains would bite into the ice that even a 4WD may spin out on.
But when you put chains on the 4WD it evens out again. I've seen times when I got out to put the chains on and just shutting the door made the truck slide off into the ditch. Then it really helps to have a chain on at least one of the front tires.
/ I have owned my last 2 wheel drive pickup #94
I couldn't get into my old driveway with a loaded dump trailer (7ton total) in 2wd, '07 Dodge 2500 diesel, learned my lesson to lock the front hubs before going up the hill!
I had the same thing happen bringing in my last load of hay last October on our private road. Short 10% grade on dry loose gravel that I made just fine with the first 4 loads. Had to back down to a lessor grade and then switch 4wd to get up the hill.
This winter the road has been covered with snow, but as long as the temperature stayed below the mid 20s, all I needed was two wheel drive even on the grades. The exception being where the private road hits the county road. It's uphill and a semi-blind corner so I want to be moving and not spinning when I pull out.
/ I have owned my last 2 wheel drive pickup #95
Most people don't want to hear their 4wd system is crap but I've seen it on many a slippery boat ramp. 2wd with a locker drives out and 4wd with no lockers sends all the power to one wheel.
You would be confusing All Wheel Drive with 4 wheel drive. All wheel drive or a full time 4 wheel drive has a differential in the transfer case to allow the front and rear axles to turn at different speeds needed for cornering. In four wheel drive that differential is either locked or doesn't exist and the power is divided equally between the two axles. Without a LSD on any axle it becomes at worst a 2 wheel drive locker with one wheel on each axle spinning.
/ I have owned my last 2 wheel drive pickup #96
I know RWD with a true locker is better than 4wd with opens for not getting stuck😁
If I'm paying for 4wd I want a locking rear and center. The only way you get stuck with that set up is to be on the frame. Most people don't want to hear their 4wd system is crap but I've seen it on many a slippery boat ramp. 2wd with a locker drives out and 4wd with no lockers sends all the power to one wheel
If you are seeing a 4x4 truck spinning one rear wheel and not the front, likely not engaging, too many wires, vacuum lines etc. I had a vacuum hub seize, truck said it was in 4x4, but no power going to front wheels as open diff only would spin the axle that had the seized hub.
Any true 4x4 truck even with with open diffs will always power one front and one rear wheel with in 4 high or 4 low. An AWD vehicle might send power to one wheel.
Some of the more expensive 4x4 systems that offer a "full time 4x4" (Like 4A setting) might either spin one front and one rear, but they still have the "lock" option of 4H for example.
I drove many a snowy road and muddy yard with 2wd trucks, manual & automatic, open and locking/LSDs, Loaded weight in the bed for years every winter.
Current 4x4 truck when in 2wd with LSD will sit and dig holes with both rear wheels spinning....shift front axle in and you are moving.
/ I have owned my last 2 wheel drive pickup #97
There are a number of selectable 4wd systems in trucks now that use an open center diff and rely on the braking system for power distribution and don't have a low range. A lot of awd system use a electronically controlled clutch or viscous coupling for the front/rear power distribution (at least the better ones).
Sent from my SM-G715U1 using TractorByNet mobile app
/ I have owned my last 2 wheel drive pickup #98
My 1998 V70R (all wheel drive) Volvo came with a Torsen diff and even though it only has 4" of ground clearance is noticeably better in the snow than my 1990 F250 4x4
AWD are indeed better than 4wd on paved roads when the snow isn’t too deep. It falls apart when the snow gets deep.
/ I have owned my last 2 wheel drive pickup #99
Or ground clearance over rocks, deep ruts off road once the frame is on the ground, its not good
2012 John Deere 8235R (A60462)
2012 John Deere...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2004 Kubota M4900 Utility Special (A60462)
2004 Kubota M4900...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
TEREX RL4 LIGHT PLANT (A60736)
TEREX RL4 LIGHT...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
