Turn Signal Draining Battery
/ Turn Signal Draining Battery #1
Nativetexan_1
Kioti ck3510
Right turn signal stays on 24/7, at least until the battery goes dead. What would cause it to receive power with no key and turn signals turned off? Temporarily, I have installed a battery cutoff switch.
/ Turn Signal Draining Battery #2
You may have a defective turn signal switch - internal damage. It may also be your flasher. Many vehicles are wired such that the four way flashers may be enabled with the key off. If the turn signals use the same flasher you have a possible source for your problem. Get an electrical schematic and track down the circuit. Oh, and welcome to TBN.
Thanks for the info.
/ Turn Signal Draining Battery #4
You must go to work the same way I do everyday... oh wait, this is on your tractor? 😂
Welcome to TBN!
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
TYE 118-610 5 Shank Ripper (A63688)
TYE 118-610 5...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
