Insomnia
   / Insomnia #21
I told this story before, but here it is again. I snore! Wife wakes me up when I snore so I roll over and stop snoring. She then doesn't hear me snoring so she pokes me again, thinking I might be dead!
Last week, I had a sinus infection/ chest cold.. Snoring on my back, wheezing on my side. Dog was soft yips and licks when snoring. Thumping me and pushing me with her paw when the wheezing started.
I start growling and cussing when then thumping started.
I feel your pain. Wife just got the dog to do the dirty work.
Thankfully it only lasted for 3 nights of the sinus infection/ cold
   / Insomnia #22
Oh, and that is with 10mg melatonin, 25 mg doxylamine succunate, 750 mg of GABA, and some garden herb..... nope... same pattern. I just can't turn off the brain. All sorts of thoughts, including planning out the next project.
I was a paramedic and was always in the state of hightened awareness, and adrenaline rush For years, I just can't turn it off.... listening to that "odd" sound at night, I even hear the refrigerator turn on / off in the opposite end of the house!
But... I can't use earplugs because then I hear my thoughts!....not really, but then I can't hear all those sounds and start thinking I'm missing something important!
At least now I know that I'm not the only one going through this....
   / Insomnia #23
I've been having the same problem for the last few weeks. In my case though it's because I screwed my back up again. A dull throbbing pain will disrupt your sleep, especially when you roll onto the bad side.
-How much coffee do you drink in a day? I've had to cut back to (2) cups per day, and lately have found that I need to cut back more.
My "cup" holds 16 ounces. :D
Mountain Dew and other sodas have even more caffeine, plus are high in sugar which also can keep you awake.
-Stress will also cause you to lose sleep. From many of your posts, it sounds like you have a lot in your life.
-Are you warm enough while trying to sleep? I used to wake up at around 1:00 or 2:00, and lay there thinking about adding more wood to the fire. If I didn't do so, I would get cold so wouldn't sleep well for the rest of the night. I finally turned the thermostat from 50 to 60, and took care of that problem.
-Exercise probably will help. I know that if I'm stuck inside for two days both the dog and I are going crazy. In those cases I try to walk the road in front of my house several times per day.
Good luck. As others have mentioned, if it's a consistent problem then it's time to talk to your doctor.
   / Insomnia
But... I can't use earplugs because then ...
.... the tinnitus becomes deafening. I need music to soothe the ringing beast.
Otherwise pretty much all of the above replies in one way or another. I generally don't drink, but sometimes a shot is what makes the difference. Generic Nyquil often helps, but not always.
I can't even count the number of times I've seen 1AM in recent years. Probably as often as 1PM.
I worked graveyard for six or seven years, so that didn't help.
This time of year, the room is 60-ish, give or take a few. Multiple layers of comforters and blankets plus sweats keeps me warm enough and I can kick the covers off if need be.
   / Insomnia #26
MD is about the only caffeinated beverage I drink, and I've found that I can't drink it after 3pm or so, otherwise I'm still wide awake at bedtime.
   / Insomnia #27
Reading some of these posts, makes me grateful. I sleep extremely well. Most of my adult life I had a job where I worked 6-7 days a week. I would go to bed around 11 or midnight, get up at 6. I was asleep the whole 6 hours. I seldom turned over in the night. Now since I retired. I rarely get to bed before midnight, sometimes later. I sometimes drink coffee at midnight, I drink a lot of coffee. I go to bed when I get sleepy & usually, I am asleep in 5-10 minutes. I sleep 8 or more hours now and rarely turnover. Even sleeping that much, now if I sit down after lunch and watch TV, I will fall asleep & drop my coffee cup.
   / Insomnia #28
I see 11:50 for a couple nights. Then 3:30 for a couple more nights. Then I'll sleep through the night and wake up 10 minutes before my alarm goes off and it's a race to the bathroom.
Then it starts back over.
I can pretty much set a clock to almost pin point accuracy by my bladder Ain't getting older so much fun
   / Insomnia #29
The rare time that I have difficulty falling asleep I'll just pop a couple of ibuprofen to take the 'edge' off. A glass of water right before heading off to bed, plus having a full sport-bottle of water sitting on my nightstand to keep me hydrated over night leads to a good night's sleep.
A great mattress (I've got a "Tempur" (y) (y) (y) ) is also 'key'.
On those rare nights, I've usually discovered, the next morning, that a very high or low Pressure Front has occurred.
   / Insomnia #30
I had that for about 10 years. A couple of hours in surgery and about $50K later, I can get through the night without going.
Trailer (A59231)
Trailer (A59231)
Hay Spear (A57454)
Hay Spear (A57454)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
Forklift (A59228)
Forklift (A59228)
