Replacing tie rod on L3710?
/ Replacing tie rod on L3710? #1
Blackgreyhounds
Palmyra, PA
Kubota L3710 HST
I broke my right side tie rod today. I'm planning to replace both parts. Any advice / hints on how to do this? I've never done it before. Thanks in advance.
/ Replacing tie rod on L3710? #2
I recently did one on a L3301 (maybe slightly different) and its super easy.
the tie rod ends popped out very easily with small tap of a 2x4. Old one already broken so no need to worry about wrecking them (haha)
Below is from a L3301 WSM and shows you the toe adjustment made with the turn buckle and torque spec for the lock nut.
Lots of youtube vid's that give you general idea before diving in.
On the difficulty scale much easier than changing fluids.
From the L3301 WSM
/ Replacing tie rod on L3710? #3
From the L3301 WSM
THANK YOU! That's the exact same tractor except for the engine.
/ Replacing tie rod on L3710? #4
If hitting steering arm where tapered tie rod bolt fits won't loosen tie rod bolt then a pickle fork is your next best option.
/ Replacing tie rod on L3710? #5
Got it done today. Not too bad. Thanks everyone.
2019 F150 (A61306)
2019 F150 (A61306)
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
Rhino 7'6" Rotary Mower (A64127)
Rhino 7'6" Rotary...
