Kubota 2380 Hydrostatic question
/ Kubota 2380 Hydrostatic question #1
rockarosa
Warren Ridge, Ohio
Mahindra 4550
Was pushing snow and took my foot off the pedal and the tractor kept coasting. Realized there was no hydrostatic whing noise. The tractor moved forward and reverse but it never slowed when I took my foot off the pedal. Checked fluid and it was fine.Why would the hydro not slow down when I take my foot off the pedal or make the whining noise ?
/ Kubota 2380 Hydrostatic question #2
Did the pedal return to the neutral position?
maybe a chunk or ice/snow jammed it temporarily.
in general, sometimes I have to force the pedal back to neutral on my MF; just a little nudge with my toe or heel
That is possible. Just went out to the garage and checked but it seems clear. Pretty cold out. Maybe it wasn't returning to neutral. I will clean and lube the linkage tomorrow. Thank you for the help.
/ Kubota 2380 Hydrostatic question #4
Cold weather can make linkage stiff and also the dampener can get stiff. Some Grease is also stiff and tacky when cold and pedals don’t return the first couple of times used.
Makes sense because the tractor moved normal. I finished the driveway and it was normal except for the coasting and no hydro whine. I'll check that tomorrow Thank you !
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2013 Larson LXI292 29ft. Boat with 30ft T/A Loadmaster Boat Trailer (A61569)
2013 Larson LXI292...
2008 IC Corporation PB105 School Bus (A60352)
2008 IC...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
44052 (A55852)
44052 (A55852)
