Front End Gear Oil
/ Front End Gear Oil #1
sailorman3
Newfoundland
Kioti CK3510
I am unable to get SAE 90 gear oil in my location. What is the next best gear oil to use? I would prefer to change it out from hydraulic oil. The tractor is a CK3510. Thanks.
/ Front End Gear Oil #4
I also changed out the multi purpose tractor fluid for gear oil in my last 2 tractors. It's not a lot of fluid, why not just order it from Amazon or other mail order type company?
I am unable to get SAE 80 gear oil in my location. What is the next best gear oil to use? I would prefer to change it out from hydraulic oil. The tractor is a CK3510. Thanks.
You're saying absolutely NO 80w90 gear oil in your area?
I’m sorry I wrote it wrong. My book says to replace it with SAE 90 gear oil. I can get 75w90 and 80w90 but not SAE 90. Which would be the best? The 75 or the 80 weight. I’m in a colder climate but no extreme cold.
It would take a couple weeks for me to get it from Amazon. I was hoping to get it done this weekend. Living on a island has its drawbacks.
/ Front End Gear Oil #8
I used 80-90w in my RX, that should also be fine for you.
/ Front End Gear Oil #9
A gear oil without a winter rating will be hard to find. 75w90 is a 90 weight gear oil. The 75w "winter" simply means that it will thicken less than say an 80w.
Summary ;
75w90 and 80w90 are both 90 weight gear oils.
75w90 gear oil will thicken less when cold than the 80w90 oil.
/ Front End Gear Oil #12
Canadian Tire sells 75W-90 and 80W-90 full synthetic EP oil. Which ever is on sale and available is fine.
/ Front End Gear Oil #13
My front axle was weeping when the hydraulic oil was in it.
I drained the oil from 3 locations, and refilled it with 140W,,
a week later, it was weeping,, again.
I believe, even though I had properly drained the axle, enough hydraulic fluid was left to dilute the 140W.
I changed it again,, and added the 140W again..
THAT was the last of the weeping, it has been perfect since 2016,,
/ Front End Gear Oil #16
If your tractor is like mine, your owner's manual says you can use gear oil or hydro oil. Any GL4 or GL5 mineral gear oil around the 90W should work just fine.
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
Informational Lot - Financing (A63689)
Informational Lot...
2017 Kubota L3901 (A64126)
2017 Kubota L3901...
2018 John Deere 1025R (A64126)
2018 John Deere...
2005 American Iron Horse Legend Motorcycle (A64127)
2005 American Iron...
