Bobcat 331
/ Bobcat 331 #1
TJHVAC
Bobcat mini ex 331
The 331 mini ex loses operation of all hydraulic controls after 1-2 minutes of lowering the safety arm. The engine continues to run just no movement of any kind. I just had the control panel rebuilt due to problems and now this. The control panel flashes the exclamation symbol and I have flash codes of 06-13 & 08-21.
/ Bobcat 331 #2
here is the error codelist
XX-XX CODES Excavator Display Controller Code Description
02-16 Hydraulic/Hydrostatic Filter Not Connected
02-17 Hydraulic/Hydrostatic Filter Plugged
03-09 Battery Voltage Low
03-10 Battery Voltage High
03-11 Battery Voltage Extremely High
03-14 Battery Voltage Extremely Low
03-15 Battery Voltage In Shutdown
03-22 Battery Voltage Out Of Range Low
04-14 Engine Oil Pressure Extremely Low
04-15 Engine Oil Pressure Shutdown Level
05-09 Travel Pilot Pressure Low
05-14 Travel Pilot Pressure Extremely Low
05-15 Travel Pilot Pressure In Shutdown
05-21 Travel Pilot Pressure Out Of Range High
05-22 Travel Pilot Pressure Out Of Range Low
06-10 Engine Speed High
06-11 Engine Speed Extremely High
06-13 Engine Speed No Signal
06-15 Engine Speed In Shutdown
06-18 Engine Speed Out Of Range High
07-10 Hydraulic Oil Temperature High
07-11 Hydraulic Oil Temperature Extremely High
07-15 Hydraulic Oil Temperature In Shutdown
07-21 Hydraulic Oil Temperature Out Of Range High
07-22 Hydraulic Oil Temperature Out Of Range Low
08-10 Engine Coolant Temperature High
08-11 Engine Coolant Temperature Extremely High
08-15 Engine Coolant Temperature In Shutdown
08-21 Engine Coolant Temperature Out Of Range High
08-22 Engine Coolant Temperature Out Of Range Low
09-21 Fuel Level Out Of Range High
09-22 Fuel Level Out Of Range Low
12-21 Auxiliary PWM Switch Out Of Range High
12-22 Auxiliary PWM Switch Out Of Range Low
12-23 Auxiliary PWM Switch Not In Neutral
13-05 Fuel Shutoff Hold Solenoid Short To Battery
13-06 Fuel Shutoff Hold Solenoid Short To Ground
13-07 Fuel Shutoff Hold Solenoid Open Circuit
14-02 Fuel Shutoff Pull Solenoid Error On
14-03 Fuel Shutoff Pull Solenoid Error Off
20-02 Two Speed Error On
20-03 Two Speed Error Off
21-02 Glow Plug Error On
21-03 Glow Plug Error Off
22-02 Starter Error On
22-03 Starter Error Off
26-02 Front Base Solenoid Error On
26-03 Front Base Solenoid Error Off
26-05 Front Base PWM Short to Battery
26-06 Front Base PWM Short to Ground
26-07 Front Base PWM Open Circuit
27-02 Front Rod Solenoid Error On
27-03 Front Rod Solenoid Error Off
27-05 Front Rod PWM Short to Battery
27-06 Front Rod PWM Short to Ground Excavator Display Controller Code Description
27-07 Front Rod PWM Open Circuit
28-02 Diverter Solenoid Error On
28-03 Diverter Solenoid Error Off
31-28 Interrupted Power Failure
33-23 Main Controller Not Programmed
35-05 Hydraulic Fan Short To Battery
35-06 Hydraulic Fan Short To Ground
62-04 Load Moment Monitoring In Error
63-05 Console Switch Short To Battery
63-06 Console Switch Short To Ground
64-05 Switched Power Relay Short To Battery
64-06 Switched Power Relay Short To Ground
64-07 Switched Power Relay Open Circuit
65-05 Workgroup Lockout Solenoid Short To Battery
65-06 Workgroup Lockout Solenoid Short To Ground
65-07 Workgroup Lockout Solenoid Open Circuit
66-05 Travel Pilot Pressure Short To Battery
66-06 Travel Pilot Pressure Short To Ground
66-07 Travel Pilot Pressure Open Circuit Updated June 2009 EXCAVATOR ALP
/ Bobcat 331
Now that I know what the codes mean where should I start first? The machine will operate for a minute or so before losing function. I don’t think it’s running hot that quickly for error code 08-21.
how do I check the engine speed?
/ Bobcat 331 #4
on the display does it show temperature and rpm? you could have a sensor defective, does speed show up and change when you try to throttle? what temperature is displayed? do you have a way to measure it
/ Bobcat 331
The temp is at mid range. No Rpm on the display. No speed either. Throttle goes up and down fine from low to high.
2020 Case 5550 Trident (A61307)
2020 Case 5550...
1043 (A60430)
1043 (A60430)
2018 DIAMOND T TRAILER 40 GOOSENECK (A60736)
2018 DIAMOND T...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
2019 Autocar ACX Xpeditor T/A Heil 31Yd Side Loader Garbage Truck (A61568)
2019 Autocar ACX...
Kubota ZG222 (A60462)
