B73 Ber-Vac Snowblower
/ B73 Ber-Vac Snowblower #1
harmoe
tc40a
I need to know what type of shear bolt is used at the pto. ( size length and grade) B73 snowblower
/ B73 Ber-Vac Snowblower #3
The conversion is to a SAE Grade 5 bolt.
Do not use an SAE Grade 8!!!
/ B73 Ber-Vac Snowblower #6
I have the manual just gives a part #
That doesn't help much, does it?
I suggest you use a grade 5 the same diameter of what is (or was) in your snow blower.
My blower (a Frontier/Deere brand) uses two shear bolts...both grade 5's. One is 1/4" diameter (probably a 1/4-20). The other is a bit bigger (maybe 5/16th's)...can't recall the thread.
If you still have the bolts that are (were?) in your snow blower, take them to your local hardware store and get a few of each. get the best fit diameter and length (nuts too, if you need them).
I also suggest you write down the size and grade in your manual for future reference
/ B73 Ber-Vac Snowblower #7
This attached page from Ber-Vac translates some part numbers to real bolt sizes and grades.
I suspect the owner has mis types the actual model he has and perhaps it is a 74
*PN 657199-10MM X 55MM GRADE 8.8
There are other 74 blowers with different shear bolts
Dave M040
  • Bervac shearbolt list-Updated-4.pdf
/ B73 Ber-Vac Snowblower #8
Dave M040
His manual that he posted a picture of does show it as B-73. Kind of odd that that model is not showing up in the Ber Vac info though.
/ B73 Ber-Vac Snowblower #9
I did some on line searching for the owners particular model.
I think the reason it is not listed in the Bervac material I provided is because the blower is very old.
I say this because it has a 3 blade fan. All their new models come with 4 blade fans
He needs the pto shaft shear bolt it would not be difficult to try a few different diameter bolts to determine if the bolt is SAE or metric and what diameter. It will be easier than it looks because on the list of bolts for newer blowers, except for a few 1/4" sizes which are for much narrower blowers, 5/16 or 8 mm are predominant and in reality those two sizes are the same diameter shaft shear bolt.
Dave M040
Connect Hydraulic Breaker Excavator Attachment (A64194)
Connect Hydraulic...
Front Tank Bracket (A64126)
Front Tank Bracket...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2019 Kubota KX057-4 (A64126)
2019 Kubota...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2018 Trail King Lowboy (A63689)
2018 Trail King...
