TC35DA Wont start help
   / TC35DA Wont start help #1
mpilihp
Jefferson, ME
Pasquali 988
I see another similar thread for the TC33 but I think mine is different. Last time I used the tractor this weekend for snow cleanup it didn't immediately turn over when I turned the key to engage the starter. I wiggled the key and boom it turned over and started. I thought that would stink but will look at when warmer. Well I went to move it today and no starter activity. Lights on dash come on in the run position but no starter movement. My issue is I have a cab on and the way it appears you get at the switch, by lifting off the top of the dash I cannot do. That said, how can I manually bypass and engage the starter. I think I see the starter on the left side of the engine behind the bucket arm. Is the solenoid inside the starter and is there a wire there I can provide power to and engage the starter?
I just need a temp way to start it till summer when I can take the cab off.
Thank You
Phil
   / TC35DA Wont start help #2
I've often wondered that same question. Here is a picture of the starter on our TC33D if that could help someone describe what you do?
   / TC35DA Wont start help #4
So in my picture somewhere under the black cover, behind the lug which the red wire is attached, there is another terminal these two need to be connected. I guess for my situation you would need to remove the black cover.
   / TC35DA Wont start help #5
I've often wondered that same question. Here is a picture of the starter on our TC33D if that could help someone describe what you do?View attachment 731904
OK, the red cover is over the battery hot leads,
also a small red wire leaves there and goes up towards the firewall,
there is a second red wire that appears to go behind the starter solenoid.
Does it go to a terminal on the other side of the solenoid?
If so a jumper from the hot leads under the red cover to that terminal will act like a switch.
Your best way is to use a remote starter switch;
Also I would expect that there is another large stud from the solenoid to the actually starter motor the same size as the battery connection, it could be under that black cover or on the other side of it.
Thanks for the help guys, I will take a look at it.
Phil
   / TC35DA Wont start help #7
@mpilihp - There are a few things you can try / check on the TC35DA...
- Yes the starter is on the left side & the Solenoid is part of the start...
The first thing is I would check to see if you are getting any voltage at the Starter Solenoid when you turn the key to START... If you see voltage when you turn the key to the START position but it is less than 12V this will definitely cause an inconsistent starting issue. Obviously no voltage with the key turned to start is an issue but it seems this has been intermittent issue for you. Just be careful the large wire on the starter is always Hot... so be careful.
The solenoid wire is the small wire on the the starter solenoid in the picture the @thclimer posted.... It needs 12V when the key is in the start position.
You can apply 12V to the starter solenoid with the key in the run position & it should engage the starter & possibly start the tractor if there are no other issues... i.e. let you manually bypass and engage the starter.
If I'm not mistaken you ignition switch is in the right side console... if it is... it is easier to access it by removing the right side console (4 bolts) but your cab may hinder that access also... if so it can be gotten to by taking the 2 screws out of gauge cluster & pulling it out (like you are accessing the fuse box... then you can reach down inside the dash & get to the switch..
Couple other notes on the NH TC's - If the Starter Solenoid is not getting voltage then it could be any of the following: Ign. Switch, PTO or Neutral safety switch, a Relay, or the Safety Module
If the PTO switch or Neutral sensing switch / bypass is faulty, the engine will not crank over.
Let us know what you find.
   / TC35DA Wont start help #8
After I posted the picture I began to wonder about the small red wire and had to go back to my owners manual. That small red wire is a modification to the starting circuit in which a relay was added to prevent a fuse that would intermittently blow. Thanks for the suggestion of using a remote start switch!
Thank you for the info, so I understand better, to remove the right side console (where switch) I need to take out 4 bolts, but where are those four bolts? Unfortunately I am not there now. ANd thanks for idea on gouge cluster.
As for a replacement switch I see another thread where the person has a NAPA part number for one for a TC33 will this fit/work on a TC35? Is a KS6600 Seen here:
Thanks!
   / TC35DA Wont start help #10
@mpilihp - no problem hope the info helps...
so there are really 6 bolts to remove both sides of the console, but if you only want to remove the right side where the Ign. Switch then you just need to remove 4 of them (note: behind the left side is where all the relays are).
To remove the right console you will find 2 bolts on the center line of the lower console (looking directly down from the steering column) where the two haves meet. The other 2 bolts are a little harder to find... if you open the hood to the engine & look all the way back on the firewall you will see 2 more bolt heads that hold the console one (there are 2 of these bolts on each side). Again I'm not sure how easy it will be with the cab on...
A big word of caution on these bolts if you have never removed them.... Spray them really well with some penetrating oil & don't force them. These bolts tighten into brass threaded inserts that are molded into the fiberglass / plastic console pieces & if you twist them to hard the inserts snap the console pieces & they will just spin & not come out... Don't ask how I know... :rolleyes:
The NAPA Ign. Switch should work just fine... it is not a direct replacement so you will have to cut the harness on the TC & wire it up as others have. I've never done it as every time we had a starting issue it was never the switch....
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A55788)
2012 Chevrolet...
HD4 4' Blade Brush Cutter (A53316)
HD4 4' Blade Brush...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A54865)
New/Unused 14ft...
2025 GIYI VR66 Hydraulic 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
