Starting a tractor in extreme cold temperatures
   / Starting a tractor in extreme cold temperatures #41
Yes, let the engine heat up and stabilize at a warmer temperature for longer. I'll preheat mine for a day before running it, and if in doubt, I just leave ot plugged in until next time. Though I hate to waste electricity, it's still less costly than replacing a starter motor!
Just a word of caution here, unless the wx is really cold, leaving the coolant heater plugged in all the time can evaporate the coolant. Not sure how it happened, but I guess I had been leaving it plugged in all winter between plowing. I also use a magnetic oil pan heater and a battery tender. So I never had a problem starting my 1429V M/F. I discovered the low coolant when my water pump seized from no coolant. My Bad.. Here on the North East coast of Canada this past week-end was the worst storm in 4 years. For the last four years I didn't use my rear blower, so this year I left it packed away in the tractor shed, 100 feet away and impossible to reach with 3 - 4 feet of drifted packed snow.
  • Jan16:22 triple play.JPG
   / Starting a tractor in extreme cold temperatures #42
So for two weekends in a row, I was unable to start the tractor with temperature around -35C. Had to wait for the temperature to be a 'mild' -20C for it to start.
I have a 300W heater on the cooling line and installed last weekend a battery tender. The heater is turned on for about two to three hours prior to the attempts at starting it. The tender stays 24/7.
What I do is 4 cycles of 8 seconds glow plug and try to start it. At first, because of the battery tender, it turns pretty good but fails to start. Grey smoke comes out but that's it. I do a few more cycles of the glow plugs and it still fails to start. I crank for about 5 seconds each time. After about 5 or 6 attempts, battery is having difficulty turning the engine so I stop and let the temperature warm up. At -20C, after about 3 cycles of the glow plugs, the engine fires no problem.
What's the trick to start a diesel engine in such extreme temperatures?
Thanks
   / Starting a tractor in extreme cold temperatures #43
The immersion heater for the Kioti is a 400 watt unit and you have to use a spacer sleeve so the element does not contact the block. Kats has the kit. I run 15-40 in mine and have no starting issues until below zero then I plug it in. Use a 5w-40 syn for temp extremes and a stick on heat pad for the oil pan. They are flexible silicone and will form to the bottom of the pan and attach with silicone adhesive. OR just stick a 500w halogen under the pan for 30 min or so if it is really cold. You normally don't need a battery heater until you see sub -30F below. I have had all of my diesel trucks start unaided at 30 below as that is not uncommon at the cabins in Ontario [when we could actually get there] with 5w-40 and good batteries. CJ
Oh, and I did replace the glow plugs at 1200 hours as I had 2 going bad on the ding dong diesel!
if the forecast is -20 or lower, I attach my battery charger over night. I was plugging into the blockheater but it failed. (any thoughts anyone?)
   / Starting a tractor in extreme cold temperatures #44
I connect my battery charger if the forecast is -20 or lower.
My block heater wouldn’t do job. Don’t know why.
   / Starting a tractor in extreme cold temperatures #45
Doesn’t a block heater, and a coolant heater in the lower radiator hose do the same thing. They both heat the coolant which flows through the system by convection. Big difference I think is block heaters tend to be higher watts.
   / Starting a tractor in extreme cold temperatures #46
"I have a 300W heater on the cooling line.....".
I don't know what you mean by having a heater in a cooling line.
The heater should be in the block to warm the coolant in the block and the walls of the cylinders. It will heat the cylinder walls and reduce the oil viscosity locally to make cranking the engine easier. It will also help start the combustion process by warming the walls of the cylinder. I would talk to the dealer's parts department and see if they have one for your tractor. Most OEM's have a block heater for this purpose and since you are up in Canada where cold weather is the norm, your tractor should have come equipped with one.
I agree. My heater is in the engine block, I use synthetic oil just for this reason too. And, I've never had an issue starting my Kubota B7800 in the extreme cold. I really believe that this combination is key!!
   / Starting a tractor in extreme cold temperatures #47
I'm retired and have no duties that require starting my tractor in such cold weather. Besides - when it's that cold - I don't want to be out in the cold either.
However - contrary to my better judgement - I've started my M6040 a couple times with temps down as low as -20F. I ALWAYS have a battery tender hooked up in the winter. Nothing else.
The tractor will fire right up. It coughs, grunts, blows smoke for a few seconds - then smooths out and runs fine. I use PS white jug in my diesel fuel - year round.
If I had animals that required daily maintenance -
- battery tender
- lower radiator hose tank heater
- cabbed tractor
This would be a more economical alternative to a heated building/barn.
JMHO ......
Disagree. If you REALLY need to operate equipment at minus 35 C (30 below F) then for gawd sake house it in a building of some kind. In that weather at least a minimal building is an essential cost of doing business.
Agree battery tender is good, hose heater that pumps a little spurt of hot water thru the cooling system every 30 seconds or so will do HUGE wonders for your problem. Recommend 1000W or 1200W if can find one. Those water circulating heaters warm the entire engine block, the heads, everything. That alone should make it easy to start if you have fuel that has not gelled (50% kerosene for sure in your location).
Is it a cab model ?
   / Starting a tractor in extreme cold temperatures #48
I live just outside of Ottawa, Ontario. We've just gone thru a bunch of nights with temps down to -25 to -30C plus wind chill. I do keep my TN-75 in a unheated building, but it does have a block heater with a Wi-Fi plug. I generally turn it on two to three hours before I need it. A reasonably new battery, with low 5W synthetic oil. Very seldom use the glow plug, and haven't had any issues. I also let it sit and idle after a start to hopefully get the hydraulics a little warmer. The viscosity of the fluid in the lines has me more concerned with either blowing seals or other problems. I run a front end loader with bucket, and a 7-foot snowblower on the back. This is the first year in almost 15 that I put the blower on in January.
  • Good Post
Reactions: JWR
   / Starting a tractor in extreme cold temperatures #49
No, a good coolant heater pulses coolant through the engine block, heads, radiator and back again. A 1000 watt unit will make virtually any engine easy to start in an hour or two at most. The block plug type works BUT fails to circulate other than by convection. They don't tend to be any wattage -- they are what wattage you buy them as.
   / Starting a tractor in extreme cold temperatures #50
Thanks
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2013 Ford F-150 (A55973)
2013 Ford F-150...
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
