New B2601
/ New B2601 #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
The B2601 was delivered this morning. $11.44k difference for it plus 5 ft box blade and added hydraulic on FEL and JD 2025R 2015 trade-in. $13k for the JD. He had a buyer up there (Winchester) for $14k. Retail on the 2025R is about $17k. Was MSRP on tractor. Gave $1,000 off on it and $400 or 500 (don't recall which) on the loader.
Had to be flexible:
1. Wanted R4s. Comes mostly with R14s. Supposed to have more traction. Hope they're just as tough. Absolutely no tire problems on R4s since 2013 (had on a 1025R, too).
2. Wanted TnT for the box. 4 weeks to get the kits and 34 weeks to get cylinders and lines. Scratched. Fit Right does TnT cylinders for Kubotas. Kubota does not have them.
3. Wanted 54 inch bucket because I had to bob and weave around stuff beside the trails with a 53-54 bucket. Only 60 inch available. Probably will remove the bucket when doing the upper trail. Easy to do, probably easier than on the JD.
4. Wanted a B2301. Really don't need 25ish hp. The 24.5 on the JD 2025R was excessive except for digging dirt or stumps. Had to go to Winchester just to get tractor with loader. None of the 3 closer dealers had loaders. Winchester only had the 2601.
DO NOT FOLD YOUR ROPS on your B like shown. If I'd had my top link extended much at all, I'd have bent it. The top of the QH just hit the ROPS. ROPS now straight back. Will check 45 degree position to see if will clear my garage door.
/ New B2601 #2
I took the ROPS off of my 2601 for that reason
It also always rattled more than I thought it should
Otherwise I loved my 2601. Plenty of power for the size and weight of the machine, and it was nimble enough to get into tighter areas that the Lseries
/ New B2601 #3
Congrats on your new investment 🤞 looking forward to action pictures from this weekend storm knocking on your door.
/ New B2601
Well, I'm slowly getting used to the dreaded treadle pedal. Moving seat back to get a direct down stab at the reverse end helps a lot. Some pluses and minuses:
o Seems to start cold better than the JDs, which shuddered and issued slightly blue smoke. All diesels I've ever owned start with about 1/2 turn of the crankshaft, dating back to an old 1973 220D Benz. Nice thing about diesels.
o FEL seems more jerky, but the H130 on the 2025R was sooo smoooth and absolutely bulletproof.
o Float on FEL is very easily engaged, almost too easy.
o 2wd/4wd is so easy. Almost all JDs make this tough.
o Hydraulics are MUCH stronger. Flow is near 3 times.
o Idles nicely at 1,000. The 1025R was abnoxious at 1,650.
o Not many spots to put my tension cords that were held so easily on the H130's FEL.
o Tool box is way too small. Have another on order from Harbor Freight that I think will work, only $7.
o Drink holder is bigger than the joke one on the 2025R. Not sure it'll hold my little thermos. Not sure where to put my old Frontier doc holder cap that was a great cup holder on the JD. Kinda out of the way, behind and to the left.
o Parking brake is easier to disengage but seems a tad harder to engage.
Haven't connected nor used the rear PTO yet. Nice that it's covered like the mid one was on the JD. I presume the mid one on the B is covered as well. Not likely I'll use it unless I splurge and get a snow blower. Think it'd be a pain to connect the mid PTO on one.
Haven't tried that 45 degree position yet on the ROPS to see if it'll clear the garage door. JDs don't have this position: either up, down or 90 degree head bumper.
The HF QH went on with hardly a whimper, and those sliding gizmos to keep each lift arm in place are so easy to use. If I didn't have the QH, I'd replace those pins with self latching ones. With QH, I'll never touch them again unless some brush knocks one of them loose.
Odd that Kubota doesn't recommend some slippy stuff applied to 3ph moving parts. I always just squired with silicone.
Kubota definitely needs a warning on the front part of the ROPS top to not leave it dropped completely down.
Nice to have a temperature gauge. Wish we still had oil pressure and amp meters.
/ New B2601 #5
Sounds like you are reasonably pleased so far.
Good Deal!
Just wondering what motor oil you're going to use when you drain the factory fill 10W30.
Thanks & Good Luck!
/ New B2601
Good Deal!
Thanks & Good Luck!
Already have 2 five quart containers of M1 0w30 ESP bought from Advanced Auto. It plus a little left over from when I did the JD will do the B and the Isuzu for its 10 year change. The Isuzu takes 7 quarts, the B 3.3.
/ New B2601 #9
One little mod I did for my L3400 was to rig a red warning light for the parking brake. It's proved handy more than once to prevent driving off with the brake some-what engaged. I posted how I did it a couple years ago. Silicone spray lube isn't good for much other than immediate assembly. Use something like Fluid Film? Tenacious oil (from a bike shop) is good, too.
/ New B2601
Started up the B2601 and moved it outside to piddle around and let it sit idling while I piddled around and got 3 things done:
1. Cup holder attached to the hole in outer left of loader tower. It's the top to a Frontier (bush hog) doc holder. Little bit bigger and deeper than the one provided on the B behind the seat and handier out front.
2. Mounted the bottom part of the doc holder onto the inside of the left ROPS just in front of the triangle safety sign. The fire extinguisher slides right into it. Had to secure with 2 zip ties because there's no room even for a bolt head, as the fire extinguisher is an exact fit. The original lips that secured this doc holder broke off. Nowhere to bolt it.
3. Moved the roll over protection folding top to the 45 degree position. Clears the garage door by about 2 inches. Will provide more safety margin that at 90 degree position. May go back to wearing my seat belt.
/ New B2601
Got the box blade. They just plopped it into the bed of the guy's F-150 with a fork lift. He had to remove his tail gate to get close enough and then put a strap around the middle of it to lift with the FEL of the B.
My pics are a tad blurry. The old cell phone isn't heavy enough to steady it well.
Also shown is my tool box from HF. It has almost exactly the same foot print as the small one provided but is almost 3 times deeper. Also has a tray for smaller stuff like pins and little containers in the lid for even smaller stuff. Only $7.
/ New B2601 #12
Ralph,
that box blade looks a little too big for that tractor to pull. What do you think? They say that "heavy" is good on Box Blades....as long as the tractor can pull it.
Cheers,
Mike
/ New B2601
Yeah, specs on it says 514 #. The guy on youtube's Cluttered Garage with a B2601 put a 5 ft box blade on his. Can always raise it a tad.
I was shooting for maybe a 400 # one. The dealer had this one. Said he thought it better than a Landpride.
/ New B2601 #14
I pull an old 5' Woods bb with mine. Occasionally lose traction but never power.
/ New B2601 #15
Off to a good start!
Are those hydraulic lines on the right of the loader your 3rd function lines? They look a bit exposed, my dealer routed mine between the hood and loader and it is much less likely to snag branches.
Are you mounting a mid-mount mower? If not you can install a step to make getting up/down easier, and you can also go with wheel spacers. My B2601 is far more stable and feels much safer with 2" spacers.
You'll find the lights to be mostly useless too, I got a kit from ropslights.com (triple LED) and it has been fantastic for woods work and snow plowing. I did find out the hard way that they don't.. uhh .. "interface gently" with the rear QH if I put the ROPS fully down. Fortunately it just bent some metal on one light/bracket but the light still works. I now put in the right ROPs pin in the lower setting and pop out the left one when going in the barn and it clears fine (both barn and work light).
About the FEL being jerky, what RPM are you running at? You don't need much most of the time and ~2k RPM is fine for most work. Higher RPM means higher cycle speed and the lighter tractor.
/ New B2601
Too bad they couldn't have included the 3rd function disconnects with another couple spots on the loader disconnect. Not likely I'll ever use any of the disconnects as I've never ever removed a loader on any of the 3 tractors so far since 2004.
Seldom if ever use the lights. If it ain't done by 4 pm, it's not going to get done that day. It's shower and supper time.
I don't find the need for a step. Never have used a mid mount mower. Never used the mid PTO. Considered getting the LX..SU with no mid PTO: sticky treadle pedals and loud HST and too big.
This thing is better than any of the 3 JDs I've had with (in addition to some noted above):
1. Guards to the valve stems.
2. Metal covering over the driveshaft (JDs only have plastic) (I gotta crawl underneath there and see what they have for Ujoints, maybe none, e.g. other kind?)
3. 3ph raises a tad higher
4. The fuel cap actually screws on and off easier. Recently would not take 2 gallons with 2.6 hours on it. Good sign.
5. The radiator overflow container is right in front and easy to get to. Needed a screwdriver to take the top off the one on the 2025R and a funnel with long snout to refill it. Then top was hard to put back on.
6. More room to get the end snorkel off the air cleaner.
7. The brake pedal lock snaps off by tapping the pedals. Hard to get off at times on the JDs.
8. Top link is really easy to turn, e.g. that grease point maybe. Actually smaller, too. Hoping the tilt one will be equally easy. Tilt was always hard to turn on all 3 JDs.
9. Three position steering wheel.
10. Of course, 3 range HST control. Only 2 on the JDs.
A couple negatives in addition to maybe a couple noted above):
1. Absolutely NOTHING on the FEL bucket to attach anything to. JDs at least had a couple detents on top to attach tension cords.
2. Cruise control seems almost impossible to use but seldom need it.
3. No settable/but bypassable on the 3ph control. There's a stop, but you cannot bypass it. I likely won't use it. Just will note where it has to be for the bush hog. Not even sure this one's adjustable stop is even there.
One negative that I haven't contended with is the 2 drain points on the crankcase. Will experiment with which one is emptied using my oil extractor. Maybe there's a connect between them at front or back that allows both to be sucked dry. Tried this on the JD 4010. Opened the drain plug and NOTHING came out.
/ New B2601 #17
Yeah one think I like on my Deere is that the position control stop can be bypassed while leaving it still set. A number of other things as well, all these tractors have their plusses and minuses.
IMO Kubota notching the engine sump to route the front driveshaft higher up is well worth having a second drain plug.
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
