New tractor arriving this Friday. What do I need?
   / New tractor arriving this Friday. What do I need? #41
If you mount the bucket hooks near the reinforcements as shown and use backing plates, you should have no problems. Also buy yourself a good quality chain.
You might consider doing what I did on a small tractor that I had. I bought a piece of heavy angle iron the length of the top of the bucket. I welded to hooks to the angle iron, then bolted the angle iron to the top bucket lip using grade 8 bolts. After 20 years of using the hooks, my bucket was as straight as a new one. The extra steel makes a difference. But yes, mount the hooks where Airbiscuit indicated.
   / New tractor arriving this Friday. What do I need? #43
Maybe the most necessary and most obvious add-on has been overlooked.
   / New tractor arriving this Friday. What do I need? #45
Wait a minute - is this gonna be like my Jeep? (Just Empty Every Pocket)
As with every toy I buy, the toy is just a down payment on the finished product .
And in defense of Jeep, it IS the leggo's of automobiles. Ask me how I know.
   / New tractor arriving this Friday. What do I need? #46
I am in N AZ and the land is dead flat. I will be using it for general property maintenance, moving dirt and DG, clearing weeds and rocks, plus livestock cleanup. Pretty light duty I think.....
DG? Driveway grading?
   / New tractor arriving this Friday. What do I need? #48
My brand new 2009 Kubota M6040 started life with - FEL & bucket, RimGuard loaded rear tires and rear blade. Since that time - Wholly Carp - $$$$$$. Upgrading all my implements to Category 2.
A tip for you. You have RimGuard loaded rear tires. Purchase a good tire gauge. Adjust your rear tire pressure to this level - on hard dry ground you can see chevron prints in the dirt for the full width of the chevrons. From this point on - hold the tire gauge in reserve. Just drive the tractor out onto hard dry ground and take note of the chevron marks.
I have R-1's on my tractor. A satisfactory "chevron print" for my rear tires = 16 psi. I haven't had to use my tire pressure gauge, for the rear tires, in over eight years. The front tires aren't loaded. I check them every spring.
BTW - I keep a roll of paper towels in the tool box behind the seat. It's good for wiping my hands - and many other duties - when I'm out on the property.
   / New tractor arriving this Friday. What do I need? #49
Make sure you have wrenches or sockets to fit everything. I had to get a few larger sizes, like 27 mm. Also, pins: hair pins, cotter pins, anything that can be pulled out. I had to replace some several times before I zip tied them together. To go with the grease gun, get a box of zerks. And a spinner knob for the steering wheel.
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
