Help IDing a disk harrow
/ Help IDing a disk harrow #1
buckeye021
TO-35
Hello, can anyone identify the make or model of this disk harrow? I am replacing a few parts, and could probably use some universal parts, but I'm curious what it even is. It adjusts the cutting by removing the pin and pulling that lever in the front. Thanks!
/ Help IDing a disk harrow #2
Hello, can anyone identify the make or model of this disk harrow? I am replacing a few parts, and could probably use some universal parts, but I'm curious what it even is. It adjusts the cutting by removing the pin and pulling that lever in the front. Thanks!View attachment 731620
Looks like a 1980s IHI import from Asia. The tubing and welds look much like my 3PT auger from that era. Most IHI stuff has no labels nor ID plates. IHI was bought out in the mid-00's. So, there isn't any replacement parts anymore.
That is one whacky 3PT setup and adjustment.
If you do upgrades, change out the front 2 gangs with notched discs. It will be a serious improvement.
Thanks for the help. It gives me a place to start (y)
/ Help IDing a disk harrow #4
The International TG brand was an Asian clone of the American IH (International Harvester) and others. 1984-2008
Here's the IH that looks close to your setup. It's more like the IH Cub but not at all like the IH McCormick
Here's the ID plate on my auger that's been painted 3X.
It's rare to find anything on the web about International TG these days.
This is their old website on the WayBackMachine
A bit more products later added
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
LMC Box Blade (A64126)
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
