Just picked up a 336.. couple quick questions
   / Just picked up a 336.. couple quick questions #41
Always use a small amount of W-D 40 in my Key. My Org. key is has a major bend in it. It was in the Ing. IMHO. Shipping! How it bent that far ? to the day It was real snug when first bought it and kept outside also. It was all intact dirty as could be but stayed under a Vinal tarp until I finished an addition to a carport... FWIW. While I have it out.
DBP-4145 330,336,2500,2610,3000,3110,3810
DBP-4312 2001,2010,2020,2202,2220,2402,2420.2301,2310
DBP-4420 1601, 1610,1700B,1702,1720,1810,1820,200B,2002,2210B
DBP-4327 2620,2820,3220,4220
Fred. and add H for Hoye. Usually works
   / Just picked up a 336.. couple quick questions #42
Always use a small amount of W-D 40 in my Key. My Org. key is has a major bend in it. It was in the Ing. IMHO. Shipping! How it bent that far ? to the day It was real snug when first bought it and kept outside also. It was all intact dirty as could be but stayed under a Vinyl tarp until I finished an addition to a carport... FWIW. While I have it out.
WD40 never worked, but the clear rubbing alcohol always did. ;)
There are more dashes, but not enough aftermarket coverage for them all. 3D printing has brought solutions to the aftermarket in the polycarbonate plastic. Hoping to see more products like that for front grills and headlamp bezel covers too.
   / Just picked up a 336.. couple quick questions #43
Don't know much of plastic's if that's what your referring to? Yanmar being World Wide with so many different Tractors I tried to make it apparent Hoye and Fred. These# Fredricks refurbishes. I believe Hoye may have more parts to offer but I'm sure Fredsricks may have a Acct. with them or the same source?.............. That printing buisness sounds fancy. W-D 40 never worked ?
This is my 336. The compression release cable is missing. Ordered it.
Tph speed control lever thats frozen. Been spraying it and tapping on it lightly. I may take a wrench to the retaining nut and see if it unscrews.
This is the valve that's also frozen the big port up on the upper right is the aux hyd takeoff.
   / Just picked up a 336.. couple quick questions #47
The keystart was moved. It was originally on the dash. The replacement in the lower panel is a Hoye aftermarket type. It all looks like the same setup as the Gray Market YM2610 dash wise.
Yes there is a spot on top with a plug in it and the nomenclature around it.
   / Just picked up a 336.. couple quick questions #49
   / Just picked up a 336.. couple quick questions #50
That little cylinder knob that rotates about 90-degrees places the machine into creeper mode.
My YM2610 also has the same creeper control. Just mounted differently, but spins the same direction.
Does the YM336 have this little lever when you flip the seat forwards to reveal the hydraulics?
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2018 Chevy Silverado 1500 4X4 (A56435)
2018 Chevy...
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
