DPF Regeneration driving me crazy...
/ DPF Regeneration driving me crazy...
Are we talking gas or diesel engines? Tacoma, I presume gas. Even gas engines do not reach expected performance at idle and probably become prone to fouled plugs if idled for extended periods regularly.
My thoughts are along those lines, as it us gasoline powered..
/ DPF Regeneration driving me crazy... #103
I sure liked those old 790s: steel everywhere and cast iron transmission cases and axles. I wish they still sold JDs like that.
They still do. The hood on mine is synthetic but the rest of it is steel and cast iron, just like the 1965 110 sitting next to it. I think the synthetic material the 5075E's hood is made of is sturdier than the 110's fiberglass hood, though.
Regarding regenerations, mine did this at exactly 100.0 hours. A light on the instrument panel turned on and the exhaust smell changed to smell like a combination of curing paint and a diesel engine running rich. There was no smoke or anything. I kept doing what I was already doing and the light went off after about 15 minutes and that was it.
/ DPF Regeneration driving me crazy... #104
I looked at JD before buying my Kubota because my last tractor was JD. The ones I saw at the dealers last year had plastic hoods and fenders, and plastic just about everywhere else. The transmission cases were aluminum. They appeared to be cheaply made, even though they were the most expensive brand. Just my impressions, your mileage may vary.
/ DPF Regeneration driving me crazy... #105
A few of the compacts like the 3E series have an aluminum transmission case, and some of the compacts do have plastic fenders. I know that the other 3 series machines (3D and 3R) as well as all of their larger units have iron transmission housings. Deere has been using synthetic materials for hoods and cowlings for a long time, they had been that way on their utility tractors since at least the 1990s.
/ DPF Regeneration driving me crazy... #106
You saw the 3 series. I think it's the only one with Al tranny housing. They do use plastic which I don't really have an issue with. I get some pretty hard hits on mine without bending anything. If they were metal they would get dinged up. I have no idea what the big deal is about metal vs plastic. Both have good and not so good points.
/ DPF Regeneration driving me crazy... #107
My issue with plastic is that I live at high elevation, and the UV destroys all forms of plastic. It all becomes brittle over time. Also, the 3 series was the same price range as my steel Kubota. I’m sure that Deere has some better machines than the 3 series, but they aren’t price competitive.
/ DPF Regeneration driving me crazy... #108
In the grand scheme of things it is just a minor inconvenience, or no inconvenience at all if you are doing work at constant throttle. I rarely park and wait during regen with my Kubota M8560.
/ DPF Regeneration driving me crazy... #109
I bought a 2018 Massey 1734 and it had the DPF. I got annoyed with it and traded it in for. 2019 2706 which is a 60 HP tractor. It does not have a DPF and it was worth the upgrade!! Not only for the extra HP to work some bigger implements, but no more re-gen! Some people say it 10-15 minutes every 75 hours… what’s the big deal. I find it would re-gen much more frequent then people think.
/ DPF Regeneration driving me crazy... #110
So, What's a "Regen" ??? And what's this DPF everyone's talking about ???
/ DPF Regeneration driving me crazy... #112
My M7060 Regens about every 10-12 hours regardless how I use it. It's no big deal, except I know someday it'll be an issue and expense. They could keep the air clean without putting junk on our tractors.
/ DPF Regeneration driving me crazy... #113
The problem is not all tractor work requires high RPMs. Heck I use the BH at ~1700 RPM half the time. On the M4 when I'm in H6 it is governed at 24 MPM and 2050 RPM which is below the regen threshold, go figure. Just "keep it at high RPMs" briefs well but doesn't necessary work in the real world.
True.
/ DPF Regeneration driving me crazy... #114
I knew the regeneration cycle would be happening as I kept away from the larger diesels as my buddy burnt two engines up on his trucks. But the regeneration lights come on, right as I am in the middle of something, or it starts beeping and I have to stop immediately out in the field and find a empty spot to regenerate so I dont set the whole forest on fire. This is nuts...
My MF 1739e was doing that every few hours, then the ECM light came on and took it in to the dealer. They ended up replacing the entire DPF system. They also alerted me to the filter under the tractor that feeds the DPF that was not in the MF training on the subject.
Since getting it fixed, mine recycles while I am working the tractor, and now, about every 30 hours or so
/ DPF Regeneration driving me crazy... #116
Don't get me started about power plants. The stories I can tell.... Yet another industry the guvment has gotten their hooks into and completely screwed up.
/ DPF Regeneration driving me crazy... #117
Hence why I jumped on my LS P7010C in 2014. Interim Tier 4. Mechanical DI, no emissions.
CT
/ DPF Regeneration driving me crazy... #118
B.S. My Kubota M6060 has done 5 Regens in 75 hours. What a pain in the azz!! I run it at 2200rpm consistently.
It depends on the weather you are using the tractor in. When it is cold it regens less often because there is less condensation accumulation.
/ DPF Regeneration driving me crazy... #119
Because he knows one day it will fail and be expensive to repair.
I get its Here and not going anywhere and we have to accept it and the benefits of cleaner air are good, too!
It’s just more costly and prices go up to compensate for it
Very true... it will fail.
My Motto though is "Everything Fails".
Entropy - The movement of energy from hot to cold, Its the great equalizer that spans the known universe.
It's even more of an equalizer than inflation, the ever mutating Covid strains, or importing votes over the southern boarder in the middle of the night (as if lights in darkness haven't yet been invented). Its the proverbial elephant in the room or the Emperor that's wearing no clothes - Who's the first to tell anyone we can indeed see in the dark?
Every atom that we rearrange into something that isn't dirt ... makes its way back to dirt. That's why I appreciate FARMERS... they spend most of their abilities and experience working with the universe's most abundant material and making it work for them!
But I digress:
Yes, the DPF Canister Replacement is probably as expensive as any other component that may or may not be needed at some given time, depending on who's making the calls (the Govt, the Manufacturer, or the Consumer), and don't forget the geo-political climate at the time.
Yes indeedy... "Everybody gets a vote on everything!", even though it's just possible that it's probably those much smaller controlled groups that are managing the gathering, sorting, manipulating, counting, validating, loosing, adding, hiding, finding, printing, disposing, forming, critiquing, tallying, translating, generating, purporting, AND reporting of the votes that choose!
/ DPF Regeneration driving me crazy... #120
I purchased a 2019 MF 1739E for our place. Mostly bucket work. Currently 112hrs. Regen approx every 5 - 6 hrs. Before the starting issue and taking it in. I was bad at running higher rpms. Tech told me to work it so l do now. At 107hrs it started and died in 5 - 10 sec. Hard to load on trailer lol. The tech said it was sooted bad. Cleaned and returned back. No charge. At approx 4 - 5hrs since return, it did a regen. Seems MF has a issue with these coming out of India...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
INOP/NON-RUNNING 2000 Sterling L9500 Cab/Chassis Series Truck, VIN # 2FZXEWYB3YAG90325 (A61165)
INOP/NON-RUNNING...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A61568)
2009 Chevrolet...
