CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,218
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Those modern O-ring chains used on about 80% of the more costly motorbikes (with chain drive) are the cat's meow.I think that using chain lube for street motorcycles, carefully, would be the way to go. That kind of lube is made to stick to chains moving at high speeds.
They really NEVER need lube in a low speed application unless the chain get's washed clean.
Though I do lube the motorbike chain with "Chain-Wax" at the beginning of every season.
Carefully applied with the extension tube, spin the chain around the sprockets a few times to let it work in. Then walk away for a day...
