Rotten rims, two sizes on tires
/ Rotten rims, two sizes on tires #1
SkyePN
Mountains of BC
MF 135
Need to replace the rusted out rims on my MF 135, but my tires are marked with two sizes:
14.9/24-13/24
Can't find any info on why two sizes would be shown? Below those it says "on W13 rim"
Is the second size the rim recommendation?
I've been searching online and I can't find any 13/24 rims, this page says 535454M91 is for 13x24 or 14x24 tires:
They are just plain 6 bolt rims not power adjust.
Thanks
/ Rotten rims, two sizes on tires #2
This specialty vender will probably have any rim you wish in stock:
I'm in Canada so I'd prefer to order from Sparex or a local tractor dealer once I've figured out what I need.
/ Rotten rims, two sizes on tires #4
14.9x24 tires are mounted on 12x24 wheel loops/rims.
I got mine off eBay a while back.
/ Rotten rims, two sizes on tires #6
Thanks. I guess I will just stick a tube like this in it? Anything else I need? Tire has some cracks but it's good enough
That's what I did. I'd recommend air/water valves if the tube doesn't come with them. They're cheap enough and allow you to load the tubes/tires with liquid ballast. My tires are very likely original from 1964. They have cracks in them like crazy. I will run them until they fail.
If your old wheels rotted out, you might need new hardware (the six carriage bolts that fasten the loop to the center). The MF fine thread bolts are expensive, I went to the hardware store and grabbed some course thread carriage bolts and used them with a good bit of loctite. No problems thus far and it's been over three years...
/ Rotten rims, two sizes on tires #8
Is that one of these (TRCH3?) valves?
Thanks for the heads up about the fine thread carriage bolts
No problem. Yeah, those are what you're looking for I think. You might want to check the tubes first to make sure they fit. I ordered some and when they showed up, they were the wrong ones. I had to put teflon tape on the valve stem, a steel valve stem cap, jack the axle up, and pray that it wouldn't puke all my calcium all over the place haha.
There are at least two different types, I can't remember what type I needed. Probably depends on the tube/valve stem?
/ Rotten rims, two sizes on tires #9
I can’t seem to find quality metal valve stem caps that hold up in brush. Anyone know a source?
/ Rotten rims, two sizes on tires #10
Getting your valve stems taken off? Maybe time to weld a small pipe nipple to the rim and put a pipe cap on it for protection?
/ Rotten rims, two sizes on tires #11
The rims have a factory ring welded on to protect the brass (?) valve stem but the caps keep getting rubbed and damaged. Mostly used for light brush or tall grass/weeds mowing.
/ Rotten rims, two sizes on tires #12
I'd just weld a small extension on the ring, even a few solid tack welds would be good. Use a cut piece of pipe nipple with threads already on it so you can put a cap on there. I'd probably make sure there's a small hole to allow any accumulated water to drain out. Keep it simple, there's probably a simpler method I'm not even thinking about.
/ Rotten rims, two sizes on tires #13
Did you find your rims? I am looking for 13” x 24” rims as well. My tires are 14.9 x 24 and like yours said on 13” rim. Been looking at US made Carlisle tires which also call for 13” rims. All I see are 10”-12” wide rims.
/ Rotten rims, two sizes on tires #14
What year and model is your 135?
/ Rotten rims, two sizes on tires #15
1966 model MF135, at least I think so…
/ Rotten rims, two sizes on tires #16
Different ways of measuring tires, there have been several over the years.
This article explains it quite well,
a link to the article; Tractor Tire Size: Find the Right Tire for Your Antique Tractor
Tractor Tire Size: Find the Right Tire for Your Antique Tractor​
Author Photo
By Ted Buisker​
After going to some shows, I have noticed what I perceive as a problem with restorers and the rear tire sizes they select for their restorations.​
The problem seems to stem from the progression of numbers used in tire sizes over the years.
Having worked 17 years for Goodyear at that company’s tractor tire manufacturing plant in Freeport, Ill., and on tractor tire molds, in particular, for a number of years, I would like to share what I have learned regarding rear tractor tire sizes.
Early tire sizes reflected rim width​
When rubber tires were first mounted on tractors, nearly all were mounted on 8-inch-wide rims, and the numerical sizes on the tires reflected this.
After rubber tires on tractors became more accepted, it was discovered that wider rims contributed to better tire performance. The wider rims actually made the tire wider because the beads were no longer pulling the tire together. Tires labeled “11.25” were 13 inches across at the shoulders. The tread was allowed to flatten out some and the tires became more efficient.
As recommended rim width increased, tire numbers followed – but tires remained the same​
The industry resized tire numbers to reflect the new recommended rim width. As an example, let’s use the 11.25-24 tire, as used on the early WCs with 8-inch-wide wheels. This became the 13-24 when used on a 12-inch-wide rim.
It seems to be the same exact tire from basically the same mold as the old 11.25-24, only renumbered to reflect the recommended use on the wider rim and the corresponding increase in effective tread width gained by the wider rim.
Tires renumbered once again to reflect overall carcass width​
Later on, in the late ’50s or early ’60s, the tire manufacturers again renumbered their tires. These new numbers referred to overall carcass width when mounted on the recommended rim width. With this change, our 13-24 grew to a 14.9-24. Keep in mind this is still the same size tire, physically, from basically the same mold. It’s just labeled according to the new numbering system.
The tires on each line were the same size and formed in basically the same molds but they were numbered differently to reflect: first, the increase in recommended rim widths; and second, to reflect over all carcass width rather than shoulder-to-shoulder width across the tread.
If you will notice, some really old tires are labeled with both sizes. I have a pair of Goodrich that shows 13-24, replaces 11.25-24.
Evolution of a Few Typical Tire Sizes
Old 8-Inch Rim
(pre-1940)
Wider Rim
(1938-1960)
New Measurement
(post-1950s)
11.25-24 13-24 14.9-24
12.75-28 14-28 16.9-28
13.5-28 15-28 18.4-28
Things to keep in mind about tire sizes for antique tractors​
It also should be noted that the tire industry adopted a more aggressive tread pattern about the time the first size change went into effect. And, you must remember that rear tractor tires evolved from existing sizes used on aircraft, so there may have been a slight increase in physical size when molds were developed exclusively for tractors.
Most restorers are aware of the second change, but few are aware of the first change. They go to the original owner’s manual, look under “tires,” see “13.5-28,” and purchase a set of 14.9-28s, thinking they have the proper original size.
They do not realize the 1927 13.5-28 is now an 18.4-28. And if this seems a big jump, you must remember the 18.4-28 has a recommended rim width of 16 inches, double the width of the original rim used for this tire in 1937. If you squeeze those beads together by 8 inches, the tread shoulders probably will come in that inch and a half. Remember, the first two sizes are based on tread width; the last is based on overall carcass width.
I hope I have shed some light on rear tractor tire sizes and their evolution over 65 or so years. If you thought some tractors at shows looked not-quite-right because their rear tires seemed small or odd, you probably were right. The restorers used the best information they had, and should not be faulted for this common mistake. Based on this assessment, however, if a tire looks small or odd, restorers may be justified in using a larger-sized tire without feeling they are not putting an “original” size on a tractor.
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
IRANCH SEMI-AUTOMATIC QUICK CHANGER (A60736)
IRANCH...
2007 Mercades GL Sedan (A60352)
2007 Mercades GL...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2002 FREIGHTLINER CST120 (A60736)
2002 FREIGHTLINER...
