JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,022
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I suspect rebargeron is correct. Just for a side story (probably unrelated) the B2150's had a latch that had exterior teeth and allowed one to hold the clutch from fully engaging. The teeth allowed you to select how much if at all the clutch engaged. Small lever on the side of the chassis. The service manual says it was for convenience in doing maintenance. It got inadvertently latched part way one time and I could not move the tractor. Went thru all manner of panic thinking the clutch had gone out and finally found that silly little latch.
