DPF Regeneration driving me crazy...
/ DPF Regeneration driving me crazy... #1
Reddogs
Gold Member
John Deere 790 / Kubota L3301
I knew the regeneration cycle would be happening as I kept away from the larger diesels as my buddy burnt two engines up on his trucks. But the regeneration lights come on, right as I am in the middle of something, or it starts beeping and I have to stop immediately out in the field and find a empty spot to regenerate so I dont set the whole forest on fire. This is nuts...
/ DPF Regeneration driving me crazy... #2
Once every 60+ hours for 10-15 minutes. Don’t be so dramatic.
/ DPF Regeneration driving me crazy... #4
It’s very real. One of my farming friends has newer stuff. Doesn’t like it when it regens.
I will stick with older stuff until the elites comes and takes them
/ DPF Regeneration driving me crazy... #5
Do you ever load it up? Maybe something is wrong with it. Does your soot build that fast or is it regening because of a bad sensor or something? My tractor has 200 hours and no regen. Soot level is just over 80%.
/ DPF Regeneration driving me crazy... #7
I got it in May of this year. Used it for running the chipper until the loader came in September. Use it with the grapple hauling logs and brush cleanup. Plowed 4' of snow for 4 days.
/ DPF Regeneration driving me crazy... #9
You purchase a new post 4 tractor you get all the emissions stuff at no additional charge... Just think, after 2300 regens (about), you get to replace the cannister too. (Kubota estimates 2300 regens before replacement / cleaning). Don't worry, it won't be under warranty at 2300 cycles. Federal emissions warranty is 5 years. Once past that, it's your dime.
/ DPF Regeneration driving me crazy... #11
2300 regens would take most CUT owners a couple of decades.
/ DPF Regeneration driving me crazy... #12
Why it's designed the way it is but sometime in it's life, I suspect some owner (not the first one) will be on the hook for a cannister. I don't have that issue and I'm glad of that. I crank up some serious meter hours on my 2 units.
/ DPF Regeneration driving me crazy... #13
You just keep working and keep RPMs high. What doesn’t he like? Other than the light on the dash, if you’re working, there’s nothing that changes.
/ DPF Regeneration driving me crazy... #14
On the hook for a part that costs <$500 after a couple of decades of use. Wow, not really a consideration.
/ DPF Regeneration driving me crazy... #15
Because he knows one day it will fail and be expensive to repair.
I get its Here and not going anywhere and we have to accept it and the benefits of cleaner air are good, too!
It’s just more costly and prices go up to compensate for it
/ DPF Regeneration driving me crazy... #16
If you are running a constant 2200 RPM's you should not be having an excessive number of regens. High numbers of regens are usually a symptom of idling a lot. I'd keep a log and if they are occurring every few hours I'd call the dealer about it.
I actually prefer for the regen to occur when I'm working the tractor hard. You can just keep working as opposed to having to let it sit at high(er) RPM's to complete the regen when the regen light comes on while you are idling the tractor.
/ DPF Regeneration driving me crazy... #17
I used to get a sinus headache after a few hours of operating my old tractor because of soot and fumes, not with my new machine. I like that. I guess because my machine is/was open station. Probably not an issue with a cab.
/ DPF Regeneration driving me crazy... #18
Why do you stop working? Just keep going. Had them on the VW TDI. Horrible if you shut it down in the middle of one. Stinks. But never restarted to let it finish.
/ DPF Regeneration driving me crazy... #19
I had one of those VWs. Great car and no diesel smell. But I wouldn’t shut off during regen.
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
60in Hydraulic Forks and Frame Skid Steer Attachment (A64553)
60in Hydraulic...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
2022 EZ-GO ELITE...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
