Mini split questions?
/ Mini split questions? #21
I'm seeing mini-split and ducting in the same sentences a couple places above, I think. I was under the impression that all mini-splits were ductless.
/ Mini split questions? #22
Mini splits are ductless. They fo use the same condenser unit. Mini splits are great gor retro fitting, getting heat/ac in areas that would be tough to run ducts to.
/ Mini split questions? #23
I'd at least get quotes for improving the ducting. It might be less than you think.
We had an energy audit done for our house which cost $600 but told us what improvements would be the most cost effective. Sometimes there are programs for free or low cost audits. We ended up getting a bunch of ducts resealed and re-insulated, and a new return added, for a quite reasonable (for California) price.
If the unheated side of the basement is well ventilated then the air in it won't be all that much warmer than outside.
/ Mini split questions? #24
My house has 5 bedrooms & a full bath upstairs. Getting heat upstairs is a problem because the ductwork is by today’s standards too small, uninsulated and runs up an outside cold wall.
I’m thinking a mini split may be my best solution.
I have a full basement 1/2 is heated and the other 1/2 is not.
The un-heated side is fan vented outside year round and the basement temperature is 50~70 year round.
I’m thinking that mounting the compressor in this area would make sense and be more efficient than mounting it outside to extract heat in subzerod temps. (Think geothermal temperature stability)
What are your thoughts?
If I understand, you are thinking of placing the 'outdoor' unit inside the unheated side of your basement rather than outdoors. In my opinion, that would not be wise. A 12000 BTU heat pump can provide 3500watts of heat but it gets it from where the outdoor unit is. You would be removing 3500w of heat from your basement and it would get very very cold.
Place the outside unit outside. My heat pump ran just fine the other night when it dropped to -12°F (-23°C) so they can handle cold weather.
If you heat with electricity then a heat pump is a no brainer. Down to 0°F, I get 4000W of heat for 1000W of electricity consumption.
/ Mini split questions? #25
Whoa, I missed the part of the question where it was asked if you can mount the condenser indoors! I think there's a reason why they've been mounting condensers outdoors forever. There's even clearances to mount it outside to allow adequate ventilation. I'm not an HVAC guy but Im pretty sure your condenser needs lots of airflow, a fresh air supply and needs to dissipate heat the bigger the unit the more heat it makes etc.
/ Mini split questions? #26
The term "mini split" at best, is a American made term for "new" technology that has been around as long as I can remember.
The rest of the world doesn't use ductwork to move air like the North Americans, so the rest of the world doesn't need "ducted mini splits".
However, pretty much all the big hitters in the market have mini splits that connect to ductwork. Yes, a mini split can either be ductless or ducted.
It's better to think of mini splits as leading the way for inverter technology (compressor) in the conventional high end "conventional split"systems now on the market.
/ Mini split questions? #27
I'm happy with my mitsubishi mini-split CCHP's so far. It's -12oF right now and no problem with heat. They work down to -25oF. Keep the outdoor unit out of the snow and out of windy areas. A roof overhang is a good idea too. Place the indoor unit where you want the heat. Mine are very quiet.
Not certain what a CCHP is (cold climate heat pump?), but if the OP were to use a Mitsubishi multi zone hyper-heat system, once you hit 4 zones, you're required to use a branch box. For myself, for residential applications branch boxes are a pain in the butt. Also, once you get over a couple of indoor units for a multi zone, no one ever wants to spend the money for refrigeration ball valves for service work so if one indoor unit goes down, you can service the equipment while the system is still running and still pull a vacuum.
Overall just not a fan of one large multi zone system to cover all the zones due to Mr. Murphy and not having a backup.
/ Mini split questions? #28
"Low ambient mini splits are specially-designed to operate at very low temperatures. Many can run at 100 percent efficiency down to 0°F and at decreased efficiency down into the negatives. As a result, these can work in many cold climates for much of the year with needing any supplemental heat."
FYI, pretty much every mini split is "low ambient" LOL
The term you're looking for is "low ambient cooling" (which refers to generally cooling for commercial applications at lower outdoor temperatures for say computer rooms or commercial kitchens) or "high heating capacity" (which refers to heating at low ambient temps).
/ Mini split questions? #29
What does a "ducted mini-split" system look like? I'm just asking as I've not heard the term previously.
In other words, what is the difference between a conventional HVAC ducted system and a mini-split ducted system?
/ Mini split questions? #30
I believe it only means indoor components like the evaporator is concealed in the wall or ceiling vs hanging on the wall, on a convetional ducted system the evaporator etc is in your furnace. I posted some pics of both types of minisplits on pg 2 of this. In my case I had no ductwork just used electric baseboards for supplemental heat keep the place heated at 40 degrees when not there, which I found you cannot run a modern HE furnace set at that temp its really bad for it.
/ Mini split questions? #31
Dedicated one to one or multi zone use
4 way multi position medium static below
Dedicated horizontal (or some brands up flow / down flow as well).
On side note, generally where you'd use a smaller dedicated ducted unit is in bathrooms or master closets.
Generally when you get to the 4 way multi position units, if you can use one, it will be a lot cheaper to run a conventional system. Ironically enough, generally happens on my end with upstairs issues.
/ Mini split questions? #32
With most manufacturers, you can even use the inverter outdoor unit with a traditional indoor unit. This from an ad from Carrier. Pretty much standard now with most residential unitary split manufacturers...Also note, where it's going is to being able to run a conventional coil/air handler along with multiple ductless indoor units.
/ Mini split questions? #33
Keep in mind, years ago, what mini splits offered that unitary product didn't was a inverter compressor on the outdoor unit (along with the ductless indoor unit which everyone really thinks of).
However, most unitary split manufacturers now offer inverter compressors on their higher SEER equipment.
FYI, the ONLY reason why mini splits have a higher SEER is when it's matched with ductless indoor unit (no ductwork involved, and IMO it's not really comparing apples to apples).
As noted, not a huge fan of running more than 2-3 zones off of one outdoor unit for mini split use (per the OP, I'm guessing he's looking at 5 zones, and I would probably break that down to two multi zones to handle the complete the heat load. You'll also find your SEER ratings drop with multi zone vs single zone). The added reality is you can also through SEER out the window if you're dealing with 20 plus year old ductwork.
Biggest issue with multi zones is they generally don't have auto changeover between heat and cool, and the master zone dictates which mode the entire system is in. Particularly in NC where you have very mild spring and fall seasons, on larger homes with the loads for each room (square footage of windows as well as house positioning and changing temps during the day), this can cause some homeowners a headache. That said, as long as the contractor explains everything to you, should be good to go.
/ Mini split questions? #34
FYI, the ONLY reason why mini splits have a higher SEER is when it's matched with ductless (no ductwork involved, and IMO it's not really comparing apples to apples).
good points I really haven't really seen a huge increase in my electrical bill when cooling in the summer the Up has ridicules' expensive power rates. My cheaper single zone 9k unit has an inverter I learned so much buying and installing this thing definitely not an expert though, main reason for buying was the heat pump rating to -20 , vs other well known brands ratings, although its not very efficient in heating mode cooling its amazing and super quiet.
/ Mini split questions? #35
You need to be careful on what the unit is rated for (example it could be rated down to -15F, but you could only get 50% capacity at that outdoor air temp. what you really need to know is what the maximum output is for what outside air temp vs what you want your indoor temp to be (information is usually found in the engineering data NOT on spec sheet LOL).
Side note, generally the only reason why some units are rated so low is because they come with a simple basepan heater LOL
What I explain to people is on a ductless mini split, what you are paying for is heating capacity at lower outdoor temps along with cooling capacity at lower outdoor temps. There is a difference between the two and the specific unit/model.
Generally, what the model number designates is cooling temperature @ 95F outside air at a specific indoor temp along with dry or wet bulb. A 9k unit (9,000 BTU/h @ 95F OAT) may only give you 5k of heat at 14F outside air temp, and may also only give you 7k of cooling at the same outdoor 14F OAT air temp (this would be a "cheap" unit). One brand I'm fond of is almost twice the price as the cheaper 9k, but it will also give you 15k (BTU/h) of heat down to 5F outside air temp. As mentioned, the only time you really need to worry about low ambient cooling is for commercial applications, particularly with computer server rooms.
/ Mini split questions? #36
You need to be careful on what the unit is rated for, what you really need to know is what the maximum output is for what outside air temp vs what you want your indoor temp to be (information is usually found in the engineering data NOT on spec sheet LOL).
Generally, what the model number designates is cooling temperature @ 95F outside air at a specific indoor temp along with dry or wet bulb. A 9k unit may only give you 5k of heat at 14F outside air temp, and may also only give you 7k of cooling at the same outdoor air temp (this would be a cheap unit). One brand I'm fond of is almost twice the price as the cheaper 9k, but it will also give you 15k (BTU/h) of heat down to 5F outside air temp. As mentioned, the only time you really need to worry about low ambient cooling is for commercial applications, particularly with computer server rooms.
When i lived in the UP never had or really needed AC but I built on a hill with direct sun with little or no shade and with little kids, the wife, and older visiting folks, to keep my sanity I kind of needed it. Fortunately my place is very well insulated with foam and when im up there in the winter I burn wood and thats it. I installed electric baseboards instead of a traditional furnace with ductwork to keep the place at a "toasty" 40 degrees plus there's a separate thermostat in each room so I can easily control which ones to set at 40 degrees and the ones I leave off when I'm not there, I don't have to winterize the water/ sewer. I pretty much only run the minisplit in the winter, when I initially get there and build a fire to help get the place up to temp, in 2-3 hrs its pushing 70+ degrees and when the insulated slab heats up I dont have to keep the fire going everyday. I havent tried it yet but I think the mini split will maintain 70 degrees after the place is warmed up. Back to the OP your definitely more knowledgeable than most of us Have you ever installed or seen the outdoor condensing unit installed indoors?
/ Mini split questions? #37
My mini splits work great in the winter. Keeps my drafty old farmhouse nice and toasty.
Main thing I’ll say is if you plan on self installing, do plenty of research and watch YouTube videos beforehand and be sure it’s what you want to do. Installation isn’t as simple as some of these retailers make it out to be.
/ Mini split questions? #38
Some basic knowledge, mechanical aptitude, having everything prepped, plus reading and understanding the instructions before hand doesn't hurt either on a "self install unit"
/ Mini split questions? #39
The manufacturer I used had specific units designed for server rooms.
/ Mini split questions? #40
I wanted maximum efficiency on my cold climate heat pumps which is why I went with two single head units. Multi-heads have much lower efficiency and higher operating costs. It also gives me some redundancy with two separate units.
I bought them to use instead of my baseboard heaters. Reduced my electric heating bill by almost 60%.
2022 Kubota SVL75-2 High Flow Compact Track Loader Skid Steer (A64553)
2022 Kubota...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64278)
KNOW BEFORE YOU...
Bobcat 84in. Loader Bucket Skid Steer Attachment (A64553)
Bobcat 84in...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
