Kubota L3301 issues
/ Kubota L3301 issues
Kubota L3301 Weight
4WD Gear :2734 lbs
1240 kg
4WD Hydro :2778 lbs
1260 kg
Kubota MX5400 Weight
4WD Gear ROPS :3716 lbs
1685 kg
4WD Gear Cab :4251 lbs
1928 kg
4WD Hydro ROPS :3734 lbs
1693 kg
4WD Hydro Cab :4268 lbs
1935 kg
Got to get the 'boss' to loosen the purse strings for that kind of jump.
You may want to consider widening the stance of the rear tires (assuming they may be at the narrowest setting) before switching out the tires. You can do this with R1's by adjusting the rims. I did this with my L3901 and it made a huge difference in the "pucker" factor when on slopes. I gained an additional 7 inches in the rear width footprint.
I was looking at that, will go out this morning and see how that works.
Well imo you can do it will it be hard on the tractor and slow going, yes I cleared a couple acres on a hill with my old L2850 the three point BH made it work for me plus added 1500 lbs of weight to the tractor. When everything was to a point I was happy with i definitely felt a sense of accomplishment. Unfortunately I ended up rebuilding the front axle on it, new seals, bearings, and a bevel gear. I waited five years to finish the rest of the acres after I got my skid steer which ended up doing the same amount of work in a fraction of the time and no breakdowns. Good luck.
Well here is the auction price on a used wheel loader I was looking at... 2017 John Deere 624K-II Articulating Wheel Loader | Heavy Construction Equipment Loaders Wheel Loaders | Online Auctions | Proxibid
would have to break the piggy bank for that one...
/ Kubota L3301 issues #45
Your 3301 is similar in specs to my L2850 so I told you what I was able to do with it. Im unsure where a articulating wheel loader is involved? I have a 326e skid steer with steel tracks over tires with the correct attachments a larger skid steer can do a lot more work in terms of clearing land compared to a cut.
/ Kubota L3301 issues #46
Can I get adjustable rims for R4 on a L3301?
No.
You can add rear wheel spacers, which are not the same thing.
Two wheel spacers + two rear R4/industrial tires + two R4 size rims =$1,200 minimum.
Spread your existing R1 wheels/tires.
No.
Checking with my dealer to see if can get a deal on new R4 with rims, if not may have to break down and spread the R1, but they seem weak on traction in heavy use and leave terrible ruts.
/ Kubota L3301 issues #48
This post reminds me of an experience I had years ago I acquired something that was underpowered, under weight No matter what I did in terms of additional addons and upgrades it was still the wrong thing for any jobs I needed to do with it, so I finally cut my losses got rid of it and acquired something I could use. best thing I did and wish I did it from the get go. On the flip side I also acquired stuff that was to big and uncapable of doing smaller jobs without a lot of collateral damage. Good Luck
/ Kubota L3301 issues #49
R1s should not leave terrible ruts unless you are working wet soil.
Are you?
R4s will have LESS TRACTION than R1/ag tires.
/ Kubota L3301 issues #50
The R4 tire are not very good on soft ground. If you have any type of mud or swampy land the R4s will load up and become slicks. Save your money for other tools. You are going to tear up the ground with either tire. R14 tires might be a good compromise between R1 and R14. However there is still going to be places that need to be smoothed up.
If you are just clearing the land to form fire breaks hire someone with a skid steer and a mulcher. Then the L3301 will be very good at keeping things mowed down.
/ Kubota L3301 issues #51
R1 Radials may be something to consider. It's the way to go when it comes to traction, floatation, stability, wear, rider, and so much more. Although, it's not common to be used in the US on CUT and smaller tractors so it may be hard to find for these smaller tractors.
Also when the tractor the is fitted with R1 Radials, both front and rear rims will be adjustable. The R1, just the rears are adjustable.
Here is a comparison from R1 Radial (Left tire) to conventional R1 (Right tire).
/ Kubota L3301 issues #53
You ain't seen "weak on traction" until you get the R4's... there is a good reason, R4 tires are NOT sold on 2 wheel drive tractors, lack of traction.
The Ford 4400 we just sold had R-4s on it, and my father plowed snow commercially with it... mostly pushing snow banks back.
/ Kubota L3301 issues #54
Driving on snow and ice is completely different than driving on mud and soft ground imo.
Are you?
Sand and more sand, then black sugar sand that takes you down to the differential..
Problem is they quoted us $15000 to clear, so I bought the Kubota...
/ Kubota L3301 issues #58
Dumb question are you in 4wd? I assume you can lock the rear dif on your tractor. I have sandy soil and if I'm not in 4wd I'll spin r1 tires and sink with my 4150 granted I'm usually using some ground engaging implement, I also can't use the loader very well on my L2850 which also has r1s without it being in 4wd I also have to lock the rear at times. My skid steer without tracks on my property was pretty useless until I put tracks on it which has r4 tires and weighed 4 tons before the tracks.
If you hit the black sand, you have to be in 4wd or the rear tires just sink and spin. But you are right with 'some ground engaging implement', I think that will help. So looking to see what I can add without the 'boss' cutting off my 'food supply and coin'...:oops:
View attachment 729477 View attachment 729478
I am thinking that may be my fallback position if nothing else..
3PT POST HOLE DIGGER (A64278)
3PT POST HOLE...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
2024 CATERPILLAR 304 EXCAVATOR (A65053)
2024 CATERPILLAR...
