X739 Snowblower attachment stopped lifting
   / X739 Snowblower attachment stopped lifting #1
Gdarbo6844
X739
I was using my tractor to remove snow whe the snowblower attachment stopped lifting. I can still remove snow but can not lift the snowblower attachment. The chute turns with no problems and the augers work fine; just can’t lift the attachment. Any ideas why it would just stop working?
   / X739 Snowblower attachment stopped lifting #2
Disconnect and re-connect your hydraulic hoses.
   / X739 Snowblower attachment stopped lifting #4
If you can put it in a warm place or you have a salamander space heater/torpedo heater you should heat the tractor and snowblower for a while to melt any ice buildup under the frame. Hopefully the cylinder is not bent.
I had it in my garage all day yesterday and "thawed it out. Still not working after that. I looked at the cylinder and no siggn of it being bent. Prior to it not working suddenly I did not hit anything hard or unusual.
It still has me stumped as to why.
BTW, when I move the lever for the snowblower, I do not hear any sound as if it was trying to move. I looked at all the links and everything is in place from the lever to the snowblower. The chute still works and that is run by hydraulics as well, although a different line.
   / X739 Snowblower attachment stopped lifting #6
Does your X7 have the valve that allows selection of front lift or 3 point hitch? From memory I think this directs flow from one to the other but not 100% positive though.
another thought are you sure the lever is actually moving the spool in the directional control valve?
   / X739 Snowblower attachment stopped lifting #7
Can you switch hoses around. I mean hook the lift cylinder hoses to the chute ports to see if it is the cylinder or something else. More than likely the cylinder is fine.
   / X739 Snowblower attachment stopped lifting #8
What is a X379 ? Any pictures ?
Not sure I am smart enough to understand the questions you are asking but I will do my best:
On your first question, I believe you are referring with the 3 point hitch, to the ability to attach a mower underneath or for front lift, that is where the snowblower goes. The valve you refer to is under the tractor and you turn it counter-clockwise when you attach the mower and clockwise when you attach the snowblower (front). Yes, I have done that.
On your second question, I do not know how to tell if the lever is moving the spool in the directional control valve. That may be my problem if I understand the purpose of the directional control valve (which I have no idea what it looks like or where that is). How can I tell and how would I fix that?
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2020 Nissan Altima Sedan (A55853)
2020 Nissan Altima...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2011 FREIGHTLINER CORONADO (A55745)
2011 FREIGHTLINER...
2013 Nissan Juke SUV (A55853)
2013 Nissan Juke...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
