X739 Snowblower attachment stopped lifting
   / X739 Snowblower attachment stopped lifting
Can you switch hoses around. I mean hook the lift cylinder hoses to the chute ports to see if it is the cylinder or something else. More than likely the cylinder is fine.
I am reluctant to switch hoses around because they are two different types. I am concerned that the hoses to lift the snowblower may be rated for a higher pressure than the ones for the chute since the chute would not take a lot of effort and lifting the snowblower is a lot more effort. Is that s concern I should or should not have?
   / X739 Snowblower attachment stopped lifting #12
Lever moving the spool in the directional control. follow the linkage from the levers down to the control valve. The valve will hydraulic lines running to it also. The chute rotation will one spool and lift lower another. Both of these spools should move similar amount when you move the corresponding lever.
did you check to make sure the selector valve you turned has not been turned by hitting hard snow?
On the selector valve, I did check and it was not accidently rotated. However, is it possible that there is air in the line? I ask because after I had this problem starting, I did a few YouTube searches and watched a video about taking off the snowblower and putting on the lawnmower. I had watched it last Spring to make the change over. When I watched it the other day, I saw where the narrator turned that selector valve and I remembered doing that last Spring but failed to do that in November when I switched the attachments. So, I went under the tractor and turned the valve. It was really hard to turn so I used vice grips to get a good handle on it. After trying to turn it clockwise, as seen in the video, and only getting maybe a half a turn, I thought, "well, maybe I am turning it the wrong way." I turned it counterclockwise until it stopped and then tried the attachment again. This time, as the video described "if you turn it the wrong way", you will see the chute move slowly at first and then quickly move to the full stop. I saw that, so I went back under and turned the valve all the way clockwise this time (and it was a lot easier to do it) and went back and tried the attachment again. This the time the chute moved quickly and smoothly, but the snowblower still did not lift. I suspect I did not have the lever completely closed while I used the lawn mower, or, during the service of my tractor by the local John Deere dealership, someone did not completely close the lever (it was serviced with the lawn mower attachment on the tractor). Either way, the valve is completely turned clockwise and the snowblower still does not lift.
   / X739 Snowblower attachment stopped lifting #14
Switch hoses and if the chute still works and it won't lift, lift cylinder seal probably bad.
   / X739 Snowblower attachment stopped lifting #15
Can you look under the tractor and see the lift cylinder and the related linkage? If yes try operating the lift lower function to see if the cylinder moves at all.
   / X739 Snowblower attachment stopped lifting #16
The blower lift cylinder is in the front and mounted on blower mount:
   / X739 Snowblower attachment stopped lifting #17
Hello Gdarbo6844,
The hoist cylinder hoses are the same size, did you match them color for color when attaching them????
   / X739 Snowblower attachment stopped lifting #18
There is only one pressure.
   / X739 Snowblower attachment stopped lifting #19
My bad you are 100% correct which should make observing the cylinder much easier. Do the hoses stiffen or move at all, etc..
Sorry to be off this forum for a few days. Turns out the lift cylinder is the problem. I brought the tractor to my local John Deere dealer who will repair it. Fortunately, their Sales guy, who I have known for nearly 20 years, was there and said, "Greg, you are still under warranty for that so you don't need to buy parts and we will fix it." So, as some of you figured, it was the lift cylinder.
I just cannot thank everyone enough for all the great input. This is one of those rare forums for any item that I found actually useful and full of folks willing to help. Thank you all so much for your time and comments!!
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Case 460 (A53317)
Case 460 (A53317)
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
