Resolving self leveling dislike
/ Resolving self leveling dislike #81
The common factor I see on both complains about the self leveling loader is actually the Kioti loader. Looks like you're just having a bad experience due to a not very well designed loader linkage. Both of you are actually the first ones I've seen that don't like the self leveling loader, which is ok and I fully understand given the circumstances.
/ Resolving self leveling dislike #82
I think I remember the "PERFECT" loader,,
it was the hydraulic self-leveling loader.
An extra cylinder was installed on the boom arm,
as the boom went up, the oil in the cylinder would level the bucket.
If you did not want the leveling, simply hit the lever on a valve, the loader would not self-level.
Then, when the situation required self-leveling, move the lever again, you are back to self-leveling.
The OP could use this as a "fix",, add the extra cylinder, plumbed in reverse, the loader would not self level.
If you want to change back, just remove the hoses.
/ Resolving self leveling dislike #83
Just point the tips of the bale spear down a few degrees when you pick up the bale. Gives you more roll back angle. That way the bales are easier to pick up ayways. Or your spears are too short for the bales you're handling. That makes them slide off easier.
I wouldn't touch the loader for that reason.
/ Resolving self leveling dislike #84
I have the "PERFECT" loader for me: Compact telehandler
It has a self leveling loader:
Real handy with the 6' forks:
And the bale spear:
And for taking trees to the burn pile:
/ Resolving self leveling dislike #85
/ Resolving self leveling dislike #86
Yep, I remember that feeling from before I got the little compact telehandler:
/ Resolving self leveling dislike #87
That sounds like it's worth a try.
/ Resolving self leveling dislike #88
I got some pictures of my self leveling loader this morning;
at full dump;
and at full curl back;
Even with the less expensive and clumsy bale fork that sits on the bucket edge there would be no proble
with a bale falling off.
I like the self leveling 90% of the time.
When I'm chasing the last of a pile it would be nice to have more curl back to get what was in the bucket to the back and chase some more.
Loading out of a pile I have no problem getting a full bucket.
/ Resolving self leveling dislike #89
The self leveling loaders on this side of the pond, seem to get way more curl that what I've seen on this thread.
image;s=1000x700
/ Resolving self leveling dislike #90
That loader on the Branson is exactly the same loader as on the DK90. Good loader. No issues whatsoever. OP is going about his mod ideas all the wrong way, imo.
modify the bucket and the spear if need be. Don't screw around with a well designed loader. Duh.
Started fabricating the parts to mount the new cylinders, the cylinders are 2 1/2" bore X 20" stroke with a 1 1/2" ram, this should allow me to stay within the 80% stroke rule for the cylinders. I have been checking measurements and dry fitting everything to make sure I am able to achieve what "I" am looking for in a usable loader. One of the pictures is of the template for the cylinder mounting brackets.
/ Resolving self leveling dislike #92
You do nice work, and I don't doubt your plan. Help me understand how putting shorter cylinders on increases roll back?
Holycow, I'm glad you like your loader on the DK90, maybe it suits your needs but probably would not be satisfactory for my needs. As a matter of fact, the salesman that I purchased my RX from had a DK90 that he used for hay and he was also dissatisfied with the self-leveler, not enough rollback for the spear especially when going downhill and other chores that I have mentioned. I use my loader for mostly farming chores and moving dirt and gravel and it absolutely sucks doing these things. It really stands out on the rare occasion that I use the forks, I'm the operator and know fully well when and how to operate the curl function to maintain control of whatever happens to be in the bucket.(y)
/ Resolving self leveling dislike #94
I see now. It will no longer be a self leveling bucket. Shortening that rear link wouldn't have worked?
Exactly, my quick attach plate with the self-leveler, fully retracted at floor level sets at 90 degrees to the floor, I am looking to accomplish somewhere in the 70 degree range, that should allow plenty of rollback for the bucket.
Airbiscuit, forgot to mention that while the cylinder length is actually shorter the actual ram extension is longer by about 6 inches. Most or at least half of the dump/curl function on a self-leveling loader is done by the mechanical movement of the triangular brackets pushed by the raising or lowering of the loader arms.
/ Resolving self leveling dislike #97
Well, you certainly do nice work. Keep the pics coming.
/ Resolving self leveling dislike #98
The 1.5" diameter rods you mention on the new cylinders caught my attention wondering if that is going to reduce the curl force significantly. The 1.5" rod inside 2.5" bore leaves only 3.14" (just a coincidence?) of area.
1.0" diameter rods would leave 30% more area but would also bend much easier. I suppose 1.25" diameter rods are a happy medium with 2.5" bore? (Just thinking out loud here)
I'm betting that you've considered the area of the 1.5" rods and feel comfortable with it?
/ Resolving self leveling dislike #99
I don't have an opinion on the rod size. All I know is that the curl function on every loader I've ever had has always been way more powerful than the lift function. I always attributed that to leverage and geometry.
I did ponder the 1.5 dia rod vs the stock 1 3/8" rods and after discussing with the cylinder tech support group we felt this would be a good choice.
2006 UNKNOWN 43' LOADER TRAILER (A65643)
2006 UNKNOWN 43'...
2001 Ford F-550 Truck, VIN # 1FDAW56F81EC40182 (A65563)
2001 Ford F-550...
Landhonor 10.5' Telescoping Ladder (A66408)
Landhonor 10.5'...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2022 EZ-GO ELITE...
(4) Texas Built Stand Alone Livestock Panels (A66408)
(4) Texas Built...
