Ford 2600 CAV injection pump no injector port flow/pressure
   / Ford 2600 CAV injection pump no injector port flow/pressure #11
By the way, welcome to the forum. (y)
Hmmmmmm. I guess I'm clueless also. There's no way the regulating piston could get into the body unless someone picked off the floor and put it in there. Or there's more parts missing. 😏 The piston is part of the fuel inlet stack.
Does the pump still have a tag on it. I was guessing it to be a mechanically governed model DPA pump. But, just a guess. I couldn't tell by your pictures.
Mystery solved. See my post above with tag. Cav 3233f661. Now I just need to source an upper linkage plate assembly and two of those spline adapter bolts and I can reassemble and bench test. Thank you.
I normally reference a manual when going through such components, but not in this case thus far. Does anyone know if the bolts need lockwashers or locktite blue maybe?... or were they just not torqued properly probably?
Pics of the little Ford 2600 to fix up. New seat and exhaust are in hand and up next after she runs again soon.
   / Ford 2600 CAV injection pump no injector port flow/pressure #15
Nice tractor!
You may want to send "thepumpguysc" a Private Message and see if he can help with parts and/or assembly. My 3910 came with a new pump when I bought it. All I've done is replace a couple of gaskets and copper seals to stop a minor leak.
I just completed a re-paint on the 3910. Don't even have many pictures yet but here's the pump side. It's the same tractor in my Avatar but when I bought it. It stayed ugly for a long time--About 10 years.
   / Ford 2600 CAV injection pump no injector port flow/pressure #16
Brad.. r u still in Washington.??
I have those parts..
Contact me directly at my screen name @ aol.com
& we’ll discuss shipping..
Yes, in Vancouver, WA. Will email. Thank you!
Nice tractor!
Wow! Stunning restoration! Thanks for sharing. --brad
71064 (A49346)
71064 (A49346)
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
