IndyJay
Super Star Member
- Joined
- Apr 23, 2021
- Messages
- 18,383
- Location
- S.E. Indiana
- Tractor
- 2021 Kioti DK4510MS w/Loader, Grapple Prev: Massey 1250
Where you can still barrel house by the riverside?Just West of the "Crossroads".![]()
Cuts are small and they are light. Adding fluids (or weights) to the rear tires make a diffrence that is proportional to the size of the tractor.
I had never thought about this so did some math regarding two of my tractors.
JD2210 SCUT weighs 1800 lbs. I added 84 lbs of fluid. 05% of the tractor weight.
Kubota M9540 weighs 10,500 lbs. I added 1,300 lbs of fluid. 12% of the tractor weight.
2nd thatI don’t know how long it takes, but I do know that CaCl will rust your rims eventually.
1,400 + 100 + 200 (mmm) = 1,700. Thanks for correcting that for me!!!! You actually took time to look it up?? Impressive!!!(BTW, TractorData.com shows the weight of a JD2210 as 1400#, though perhaps you were including a loader in your empty weight?)
There is the possibiity of too much weight on the 3 point. Not only is there so much the 3 point can lift, but you can actually reduce the ability of the tractor to steer if you take too much weight off the front wheels.Even if you added weight to your box blade, it would be less maneuverable in small spaces than a ballast box. That may be why some do it.
If I remember physics correctly, and that is a big if, having weight further back is better than closer to the fulcrum. That would support using a box blade or cutter as counterweight versus a ballast box.
In my situation, I will load the tires and keep the RC on most of the time. No lawn to mow, just brush, so too much weight should not be an issue.
I disagree. A box blade is centered laterally on the rear of the tractor. The stabilizing force of the weight of the box blade behaves exactly the same as if all of the weight were concentrated where the center of gravity of the boxblade is (which would be centered left and right, assuming the boxblade is symmetrical).
Whether a boxblade or a ballast box does more for lateral stability depends on how low that weight is carried to the ground. A tall ballast box with a lot of weight up high (or a boxblade carried as high as the 3 point will lift it) does less for stability than a setup in which the weight is kept low.
