Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C?
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #21
I’ve aimed a blow dryer heater at filter to “un-jell” it, and been on my way.
The nice thing about my Toolcat is the return fuel line feeds warm fuel to the fuel filter when it is cold. When it gets as cold as the OP has it, all the suggestions given will help him get 'ole betsy started.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #22
What oil is in the crankcase? If using 15w40, almost any other oil will allow much faster cranking speed. For instance, if it cranks at 100 rpm (barely enough to start it), it will crank at 160 rpm with 10w40 oil and 170 rpm with 10w30 and 180 or more with 0w30.
I readily believe the principle you describe but where are you getting those rpm numbers ? Just personal estimates or does that data exist?
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #23
Wonder how that warming of fuel returning to the tank (or the fuel filter) works ? I know that the recent years of diesel autos have some means of heating the fuel lines or the returns but no idea how they accomplish it.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #24
When cold, the return fuel gets fed into the line that goes into the fuel filter. As the temps raise, the return fuel is then directed to the fuel cooler and then the fuel tank.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #25
That's kind of complex, amounting to a "thermostat" in the fuel system. Interesting.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #26
well, mines a 2010 GC2400 so comparisons may not matter but...even though I do have block heater I have never needed it even at -10F. its there for emegencies.
I keep battery tender plugged in always. I crack throttle enough (slightly under 1/4) so that when warm it idles around 1700rpm. I cycle glow plugs 60 seconds then let go of key and recycle them another 30 seconds THEN turn engine over.
its always fired up after 3-5 revolutions.
above 10F I just cycle plugs 30 seconds then tractor starts.
NO TRACTOR IS THE SAME.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #27
I have had the same results. But, apparently we are in the minority.
The guys who have one that won't start, can't understand how we can get ours to start. And, we can't understand why they can't get theirs to start. 😝
It would be interesting to have everyone all together in one spot. Then, perhaps we could conclusively determine why.
I can say that my wife can start mine, so the tractor, or perhaps the fuel, may be the difference. But, I also did explain to her how to do it. Then again, she usually doesn't listen to me, so who knows. :p
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #28
You can calculate them from the extrapolated viscosity values at whatever temperature you wish. Can only calculate relative values. Cannot calculate actual cranking speed.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #29
When it's that cold, even with a block heater the crankshaft and rotating groups for the hydrostatic system is facing huge resistance from honey-thick fluids in the journals and passages.
If you can tarp the whole thing and heat it with a frost fighter for a while, it should turn over a lot easier.
   / Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C? #30
battery is key, especially ability to cycle plugs multiple times.
IOW don't hurry LOL
GODWIN (INOPERABLE) 3,500 PSI HYD. POWER PACK (A55745)
GODWIN...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2017 Ford F-150...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
2003 Chevrolet 1500 Silverado Crew Cab Pick-up Truck (A55852)
2003 Chevrolet...
2013 Magnum Power MLG08 Towable Runway Closure Marker Light Tower (A55851)
2013 Magnum Power...
