Driveway camera/alert systems
/ Driveway camera/alert systems #1
BigBlue1
Elite Member
Middle MN
JD: 2520 & x758
Anyone have recommendations for a good system that can go at the end of a driveway and alert (via phone) when someone drives in?
My ideal system would have the following features:
- Decent quality camera, preferably with video capability
- Long range transmission to base station in house (need 600')
- Ideally solar powered
- Send me an alert via Internet/phone/app when someone enters the driveway
I've pondered cell-capable game cams but from what I've been able to learn they aren't always synchronous (i.e. the notification and picture might take minutes to receive). I've done a little web research and from what I can see, most long-range systems are only motion sensors, not cameras. That seems odd, but maybe it is due to the bandwidth required to transfer the images over long distance wireless?
Thanks for any ideas!
Rob
/ Driveway camera/alert systems #2
You could mount a regular security camera at or near the house aimed at the end of the driveway. Many of them have motion detectors as well. When they detect motion they will immediately alert your cell phone and you can see who's there. Of course a stray cat, dog, deer, or whatever will also set off the motion detector giving you an alert.
/ Driveway camera/alert systems #3
Just bought a Dakota Alert system for my driveway. A much simpler alert than your description. They offer a system to do exactly as you described.
/ Driveway camera/alert systems #4
You list 4 things, pick any one of them.
Nothing off the shelf will do everything you want. Try homebrewing your own system.
The end of the driveway is 600' from the house. No motion detector would go that far (that would not also have tons of false positive signals). Plus, the driveway curves and there are trees between the house and end of the driveway.
Well, I've seen plenty options that offer motion sensors and satisfy the last 3 bullets. Just not with camera.
Rob
/ Driveway camera/alert systems #8
600' is not beyond the do-able range of a network based camera system IF you have a home network. You may need a booster point or two though since each leg shouldn't be more than 300', give or take a bit.
AC or battery/solar could be used to power the relay points.
Network wireless links can go miles if set up properly.
Gates block access so nobody can just drive in unannounced. Gate openers and controllers can be set up with access codes you can give to delivery drivers and others you want to allow access to. Many controllers have camera and intercom/announcer capabilities and can log access code/card use so you know which card/code was used when. They can also be programmed with schedules so any card/code can only be used during certain days or hours.
But all of that costs some amount of money and takes some degree of installation time and skill.
I have that kind of controller on my front gate about 150' cable feet from the house. This is a pass/walk gate only with an electric latch. I also have a gate with opener on my driveway, but no controller. It only uses the key FOB remotes.
There is also a pan/tilt/zoom camera 20' up on a pole that watches the entire front yard and can be set to record full time, by motion activation or on a schedule.
Camera was sub $100. Front gate controller was around $100 and the various network wiring and components were another $100 or so.
/ Driveway camera/alert systems #9
How about a trail cam for hunting. The ones many are using now use cell towers and send straight to your phone. As long as there is cell service on both ends it don't matter how far away.
/ Driveway camera/alert systems #10
You don't necessarily need to install it at the end of your driveway. Could maybe put any detection system after the last curve closest to the house. All just depends on your preference, of course.
/ Driveway camera/alert systems #11
I have have blink battery powered system and I use lithium batteries in the cameras for better battery life. Furthest camera is about 105' and I would say much more is pushing its limits.
/ Driveway camera/alert systems #12
I use two different systems to achieve what you want to do.
I have a Reconyx Hyperfire 2 cellular game camera which I mount at the entrance to our 500' driveway when we are away. It takes stills and video of anything entering the drive. It alerts us on our cellphones which we can use to view the incident. It's high def pics can easily read a license plate. There is never more than a 20 second delay although this can vary depending on your location and cell provider. We use it as a game camera when we're home so it serves a dual purpose.
We also have an outdoor Nest Cam mounted on the garage within WiFi range. It has a clear view of the drive and anyone approaching the house. It also notifies our smartphones with pics and video when triggered. It auto zooms in on faces to aid recognition. The delay averages 20 seconds. It stores the images off site and can be reviewed for up to a month.
Both cameras require a subscription. The Nest cam costs $137/year which can be reduced or eliminated depending on the storage duration desired.
The Reconyx cam costs $16/month but can be activated only when needed.
The ones I've seen/heard about don't seem to be an immediate notification. More like batched or sending every few minutes. If you know of a cell-capable game can with 'instant' notification I'm all ears. That would be perfect, assuming the app would allow me to set a notification sound.
This is true, and something to think about. I have a bend in the driveway just after the trees that reduces the distance to the house to 300' with direct line of sight. Thanks for the idea.
Good tips! I'll look into those items. Thanks!
/ Driveway camera/alert systems #16
Moultrie sends pics to a cloud then sends a notification to phone then you access the cloud to view so maybe that's not gonna work for your application.
Yes, that's one of the ones that appears to have a potential for delay of up to 10 minutes.
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
(1) UNUSED 16.9-30 TIRE W/RIM (NO CENTER) (A62130)
(1) UNUSED 16.9-30...
2018 Jayco 264BH 29ft. T/A Travel Trailer (A61569)
2018 Jayco 264BH...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2017 CAT 420F2 Backhoe (A63109)
2017 CAT 420F2...
