Heat issue
/ Heat issue #1
Silverbull
Kubota rtv1100
I have a kubota rtv1100 .having heater/heating issues heater is blowing cold air when vehicle isn't moving ..when moving it blows hot air ..an also engine temperature will reach into the red zone when machine is just idling any ideas please ..maybe water pump is the issues
/ Heat issue #2
Welcome!
Please insure your cooling system is full.
Check the radiator and expansion tank,if you have one.
Good Luck!
/ Heat issue #3
Is your unit an RTV-1100 with one radiator or an RTV-X1100 with two radiators?
/ Heat issue
It's a rtv 1100 it's the older model. just the one
/ Heat issue #5
The symptoms could indicate several faults--low on coolant, bad radiator cap and/or bad pump.
If low on coolant, check for leaks AND the radiator cap.
/ Heat issue #6
dirty air side radiator passages, clogged coolant side radiator passages, stuck thermostat, bad rad cap, loose fan belt,....
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
832650 (A61165)
832650 (A61165)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Ford Escape AWD SUV (A61569)
2013 Ford Escape...
2012 Ram 4500 Truck, VIN # 3C7WDLFL4CG183200 (A61165)
2012 Ram 4500...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
