WoodMaxx Flail - Early Issues
/ WoodMaxx Flail - Early Issues #1
Kwehme09
Kioti DK5310
After buying a new property in Northern Maine we bought a WoodMaxx flail mower mode, FM-78H with hammers. It's job is to mow back the fields which haven't been touched in 4+ years. The field was almost all heavy weeds, grasses and brambles, no wood of any diameter worth mentioning other than along the very edges. We closed only a few weeks ago, and with almost no snow to mention of I figured I could get a head start on spring by mowing now while the ground was frozen and no mud to worry about.
Do to the thickness of the vegetation I started out in low and of course at the 540 PTO speed. Unfortunately, after only a out and hour of mowing the belts smoked and all three broke. I can tell they heated way top as there was a heat mark on the protective casing over the pulley housing right where the idle pulley is. Had I overdone it in the heavy growth? It didn't seem like it, the tractor was never bogging down or anything. I have a Kioti DK5310E HST, by the way.
NAPA was able to get the right size V-Belts overnight and the next day installed the new belts, and tensioned properly. Even with the spring completely disconnected from the idle pulley the belts are VERY difficult to installed due to the tightness, but I eventually got them on. I also raised the roller and skids to mow at the max height. I ran the PTO at 540 for about 10 minutes without mowing to test things out, check for wobble or overheating and all looked good. I checked the tension one more time and headed out into the field. This time the belts broke (didn't seem to overheat as much) after about 2 hours.
I called WoodMaxx and the tech was really helpful. We talked through out all, and didn't come to any firm conclusions, but he agreed to send a new trio of belts, advised me to make certain they were good and tight and also recommended I check the full alignment with a straight edge.
With the new belts scheduled to arrive tomorrow I was up in the barn this evening cleaning all the pulleys of melted rubber and getting ready to reinstall the belts when they arrive. In doing so, I noticed that the arm that holds the idle pulled had a groove worn into it from where the inside edge of the drive pulled at rubbed against it. I had not noticed this the first time I changed the belts. The pulley didn't seem to be harmed at all since the contact was on the inside edge, but this was a clear sign to me that the pulley may not be running where it is supposed to be. I through a level across the face of the two pulleys as the tech had told me to do, and sure enough the drive pulley was way too far in on the machine. There isn't any play in it, so its not like something is loose, and I have no idea of it has always been this way or not, but I'm sure that things won't run correctly with how it is. See photo.
So tomorrow I will be calling WoodMaxx and seeing how they will deal will deal with it. I am thinking I won't be happy with anything less than a new machine and even with that I will be frustrated with the down time, likely not being able to mow before snow, and need to assemble, and setup a whole new machine.
Not sure if I have any direct question here, just seeing if someone can see anything here that I am missing, or has ever had a similar issue. Also making people aware of this issue with WoodMaxx, and hopefully will be able to reply to this thread in the future with a story about a positive resolution. Fingers crossed.
/ WoodMaxx Flail - Early Issues #2
Have you tried moving things by hand without the belts?
I'm curious about what appears to be the upper pulley wheels mounted at an angle - it may just be an artifact of the photo but there seems to be more of a gap between the straightedge and the bottom of the pulley vs the gap at the top. This makes me question if the shaft may be bent or the bearings good.
The tapered gap in the photo was caused by me leaning the level in to meet the drive pulley.
Attached us an updated photo with the level flush on the lower pulley.
Both pulleys free rotate fine, so the shaft doesn't appear to be bent. I did just now notice in/out play on the drive pulley. Although, pulling it all the way out still doesn't align it with the lower pulley.
Regardless, this has to be a warranty issue... right?
/ WoodMaxx Flail - Early Issues #4
How are the pulleys secured to the shafts,
wedge tights or just keyways and set screws.
The upper pulley needs to come out or the lower in.
/ WoodMaxx Flail - Early Issues #5
I would be surprised if they did much other then tell you how to align the pulleys.
/ WoodMaxx Flail - Early Issues #6
That's all I would expect unless there is more than I see here. Looking at the parts diagram it looks like taper lock bushing in the pulleys. Pretty easy to align if you are familiar them or have the instructions. I really wonder if the belts are tight enough, or if the slip clutch is too tight or stuck.
Based on the fact that the drive pull was in so far it was carving a grove in the arm that holds the tension roller, I think its safe to say that the upper pulley needs to move out. I think it's held in place by a compression hub. Not exactly sure how they work. See photo. You can also see in this photo where the groove has been worn in the arm, just below the upper pulley.
/ WoodMaxx Flail - Early Issues #8
Looks like the tensioner was rubbing on the pulley, so the pulley has definitely to come out.
Basically, you loosen all the bolts on the hub. Then take 4 of those bolts out and thread them on the threaded holes of the bolts. You finally tighten these bolts equally, so it doesn't strip the threads, and it should pop the pulley out of the tapered hub.
Do I need to remove the pulley from the hub, or just retighten the hub into the proper location on the shaft?
Reading a bit more about how these tapered hubs worked, I'm surprised it has play in it (about 1/4 worth) and isn't just completely loose on the shaft instead. It would seem as though they are either tight, or they aren't.
/ WoodMaxx Flail - Early Issues #10
Do you need to remove the pulley from the hub, or just retighten the hub into the proper location on the shaft?
Unless you want to inspect anything behind the pulley, you don't need to pull it completely out.
Use that same level you used before on the face of the upper and lower pulley to get them inline.
/ WoodMaxx Flail - Early Issues #11
The Allen bolts for the compression pulley have to be tightened up in the correct sequence so you need to be careful and find out what the required torque for the bolts are.
The other thing is they have either a dry torque foot pound or a lubricated torque foot pound rating for the compression sleeve to work correctly.
If you do not have them you need to buy a 1/2 inch drive torque wrench and an allen socket for the allen bolts on the compression sleeve.
They obviously did not do the tightening sequence for the Allen bolts on the compression sleeve.
It also looks like the allen bolts have been damaged AND the compression sleeve is not flush with the pulley-it looks cockeyed as the compression sleeve seems to be casting a shadow.
I guess my feeling is have them come and get it and then ask for a complete refund and go to the local Maschio dealer in Maine for a Maschio flail mower.
So the plot thickens a bit. On closer examination this morning, it isn't the drive pulley that its moving on the shaft, it's the shaft itself that has play to it. It moves in/out about 3/16" when I pull/push on the pulley. Even when I pull it out to its max, it does not come into alignment with the lower pulley.
I talked to WoodMaxx this morning and they asked for photos to show the problem. I’ve sent, so we will see what the response is.
In noticing that the drive shaft itself has play to it, I also noticed that when rotating the shaft/pulley the PTO side of the gearbox only rotates intermittently. This doesn’t necessarily correspond with what position I have the shaft in relative to its play (in or out).
I would think this means that the problem is all the way back into the gearbox.
I’m asking for a new mower or refund.
/ WoodMaxx Flail - Early Issues #16
That is not supposed to happen.
Call woodmaxx and request a full refund and ask them to pick up
this flail mower as it is of no use to you.
/ WoodMaxx Flail - Early Issues #17
I would imagine the issue may indeed be inside the gearbox. The parts manual for this particular model doesn't show an exploded view of the gearbox part unfortunately, but I wonder if the construction is similar to the one on my tiller, which has a locknut holding the gears on the shafts. If this nut come loose, the shaft would get some axial play like you're experiencing.
/ WoodMaxx Flail - Early Issues #18
The cross shaft connects to the drive pulley which provides the torque to the V belts that spin the driven pulley
for the flail mower rotor.
There are 3 Maschio dealers that are either in the Great State of Maine
or have multiple stores in the New England area.
Guptill Lodging, East Machias, Me. (207)-255-4130
United Ag & Turf Fairfield, Me. (207)-453-7131
United Ag & Turf Auburn, Me. (207)-453-7131
Hood Equipment Turner, Me. (207)-225-2025
Kwehme09 I am sending you a PM
Still no word back from WoodMaxx.
I took the mower off the tractor, and disconnected the PTO. This led to me finding that the gear box was almost completely loose from the mower. There are 4 bolts (M12) that come up from inside the mower compartment and hold the gear box down, two were missing (NOT broken off) and two were loose. This would obviously effect belt alignment and tension, but it is worth noting that the movement allowed by this looseness is separate from the play in the driveshaft. There is still play in the driveshaft as well, without the gearbox moving. It basically seems like this thing was rattling itself apart inn 3 ours of use.
I know that manuals call for checking the tightness of nuts/bolts, etc. at crazy intervals, but this seems. bit over the top. I wasn't supposed to take the thing apart to check every fastener, right?
/ WoodMaxx Flail - Early Issues #20
NO, you should not have had to do anything with it.
Case IH 5100 (A64119)
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
