Looking for angle snow plow or snow pusher
   / Looking for angle snow plow or snow pusher #11
I have a 2019 Branson 1905h compact tractor. It has the skid steer type quick attachment for the bucket. Looking for an angle snow blade or snow pusher to put on in place of the bucket. With a snow pusher I don't think I would need to do anything with the present hydraulics for the bucket. Any help would be appreciated. Thank you.
You should really cancel your plow order only because you have a good chance
of damaging the loader frame if you hit something with the plow blade.
Once a loader frame is damaged like that it may not be usable for its primary task
as the frame will be wracked and twisted. and the loader mounts will have become
bent in the process.
   / Looking for angle snow plow or snow pusher #12
Pushing snow is cheap if you have a place to push it. If you are not dealing with deep snow, a rear blade is effective and cheap as well. I get about 120" a year so it was not a great option for me. I went with a blower. I ended up mounting and old rear blade ($100) for back dragging on the SSQA using an adapter for 3PH to SSQA...$220. Best of both..
   / Looking for angle snow plow or snow pusher #13
Shooter, I assume you are using the rear blade curve backward, vs curve forward which would dig in unless you have shoes or something? I have a typical snow plow blade from Kubota on the FEL arms. Pushing it forward cuts into the snow and hangs up. And I don't want to back drag 3/8 mile of a curvy gravel driveway. Jon
   / Looking for angle snow plow or snow pusher #14
Near the garage I have a cement pad so I turn the blade backwards to back drag and cut down to the cement. If we get a light snow and before I get a base on the drive, I leave it backwards, drive forward, and angle it to windrow to the center of the drive. Then use the blower to clean the center.
Using the curl function, it is easy to change the angle of attack.
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2016 Kia Soul SUV (A55853)
2016 Kia Soul SUV...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
