Oil & Fuel TYM T264 50 Hour Cross Reference Parts
   / TYM T264 50 Hour Cross Reference Parts #1
zkost
Jacksonville, FL
TYM T264
Folks,
I'm drawing a blank on the net.
The T264 comes with the Kukje A1100N2 engine.
Does anyone know the part numbers or cross reference numbers for components needing changing for the 50 hour maintenance?
Oil Filter to use?
Engine Oil to use? Looks like SAE20 or 10W30 for Florida (32F to 77F temp) @ 1.14 gal. / SAE30 (Temp over 77F) @ 1.14 gal
Transmission Oil to use?
HST Oil Filter?
Front Axel Oil to use? Looks like Gear Oil #80 or #90 @ 1.19 gal
Air Filter to use?
Fuel Filter to use?
Thanks in advance and hope our exchange helps others...
   / TYM T264 50 Hour Cross Reference Parts #2
I will look into it.
   / TYM T264 50 Hour Cross Reference Parts #3
Eng. ea00003786c Fuel hk13010022a2 Hyd/Hst 1472230100 Air 11201032020. As a dealer I do sell OEM filters. The eng oil filter is under $10.and is a Kukje #. The Hyd/Hst filter comes from TYM as a Donaldson #p169078 and crosses to a Baldwin bt8416 The air we have not crossed yet, this filter along with the eng oil filter and fuel is different than used in the older T234,T233,T273,and T293,and is around $20. The fuel filter is also a Kukje #.and as a Donaldson # p502166,as a Baldwin # pf981, and Yanmar # 119810-55650 (TYM T254,T224,T194). There is also a washable pick up screen in the trans/axle on the left side. This is very important to clean at the 50 hr service. I don't see much savings in a lot of aftermarket filters, and if its a will fit why chance it for a couple dollars saved. Your dealer providing OEM filters with the assurance of the correct filter microns and pressure ratings takes the guess work out of it. The air filter as Wix or Baldwin or what ever is not a big deal as long as a quality brand is used. The same for the Fuel filter on THIS tractor, But that is not the case for all fuel filters and other models. Most new fuel systems should be looked at the way you do a HYD system or HST/Trans. They need to be Very clean and the filters in most cases where designed for them. ENG. OIL We run 15w40 cj4,ci4 and newer ck4. Hyd/Hst we sell gulf transcrest, this is a UTF/MTF oil. A good high spec to look for is JD20c or Kubota UDT Never use a AW or the out dated 303. Front axle 80W90. Hope this helps and enjoy your new tractor.
   / TYM T264 50 Hour Cross Reference Parts #4
I found this so far:
Fuel Filter - Fram C7517 - Baldwin BF981
Hyd/Hst Filter- Fram P7537 - Baldwin BT8416
can't find the oil or Air Filter -
I'd like the same info. The closest TYM dealer to me is 1.5 hours away.
   / TYM T264 50 Hour Cross Reference Parts #5
I'm going to change my oil/filter in my T474 with the Kukje A2300N2 this weekend with 25h on it, I finally cross referenced a NAPA 1626 (Wix 51626) filter that will work, it is even a smidge longer than the stock
IMG_2422.jpg.
   / TYM T264 50 Hour Cross Reference Parts #6
When using cross reference on filters the micron rating is not always the same as OEM and what the equipment calls for. For that reason OEM is the best choice in most cases.
Tym T264 Filter Cross Overs Update (these are confirmed) If you have found additional alternatives, please update this post.
FilterOEMAlternatives
Engine Oil FilterEA0003786A(NAPA 41334), (PH2808)
Hydraulic HST Filter13152302100(NAPA 1586), (Donaldson P169078), (Baldwin BT8416)
Fuel FilterHK13010000C(NAPA 3263), (Donaldson P502166), (Baldwin BF981), (Fram C7517)
Air FilterNeed Your Help in Finding actual FilterNone known (Please update me)
Hydraulic Strainer/Suction Filter16705105000
   / TYM T264 50 Hour Cross Reference Parts #8
The air filter should be the easiest one to find. Doesn't TYM use a Donaldson air filter housing and filters, just like Branson and other manufacturers?
   / TYM T264 50 Hour Cross Reference Parts #9
wix 46449 ,546449
purolator a35270
fram CA9248
With those number you could easily find a lot more compatible other brand too
   / TYM T264 50 Hour Cross Reference Parts #10
View attachment 671581.
Have you found out any more cross reference fiters?
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
Electric Golf Cart (A56859)
Electric Golf Cart...
2169 (A58376)
2169 (A58376)
2012 John Deere 650K LGP Crawler Dozer w/ 6 Way Blade (A59213)
2012 John Deere...
HAYBUSTER IG8 INDUSTRIAL TUB GRINDER (A52708)
HAYBUSTER IG8...
