looking to buy a 3 pt tiller
   / looking to buy a 3 pt tiller #1
tbergman
Member
Tahlequah, Oklahoma
Branson, Kubota, and Case
I have a 30 hp kubota and a 47 hp branson. I will probably keep just one, but haven't yet decided. We just moved to the country where I have broken up a 4000 sq ft garden spot with a cultivator, and am getting a tiller. I am leaning toward a 5' king kutter which says 30-50hp, so it should work on either tractor. I figure I will use it twice a year; once in the fall to work in manure and compost to prep for cover crop over winter, then again to prep for sowing in the spring, working in the cover crop.
Any suggestions for that size tiller would be appreciated?
   / looking to buy a 3 pt tiller #2
5 Ft would be a Good fit for the Kubota and maybe a little small for the Branson. Ken Sweet
   / looking to buy a 3 pt tiller #3
I used a 6 foot on my 3430 and it was fine. The most important thing is to make sure the tiller is at least as wide as the rear wheels or you will always have a track left in the previously tilled row.
Excellent point! Thank you. I will check those dims. Another brand, Woodmaxx is offset 10 inches to one side, I expect so that you can get right up to a fence, which I liked, but that one was a six footer and more than double the price of the King Kutter...
   / looking to buy a 3 pt tiller #5
Get one wide enough to overlap your wheels by about 4” on each side.
   / looking to buy a 3 pt tiller #6
Once I sold the NH and bought the Toolcat, my 5' KK tiller is now 6"+ narrower than the track. I just offset the tiller using the 3pt stabilizers so it covers one tire track. Then, the final pass has no tracks because the tires are in the grass. (y)
   / looking to buy a 3 pt tiller #7
Like with most everything else, you always get what you pay for. Think I'd peruse Tractor House for a used one.
   / looking to buy a 3 pt tiller #8
You have the advantage of not needing it right now so just be patient and something will turn up. I use apps like "Search Tempest" to search all of CL when I'm on the hunt for something. Sometimes I find it a few hours away, but if the price is right my time is worth it.
Mine is also a KK and it has held up well. I just use it for my personal garden and to help out a couple of neighbors so it really doesn't get much wear.
Clever! Will keep that in mind.
Good to know. The brand looks solid and they are well priced. Thank you for the feedback.
Cowboy Wooden Statue (A55853)
Cowboy Wooden...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2022 CATERPILLAR 259D3 (A53317)
2022 CATERPILLAR...
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
Hustler 60in Zero Turn Commercial Mower (A55851)
Hustler 60in Zero...
UNUSED SDLANCH SDLJC HIGH-END MOBILE JAW CRUSHER (A57192)
UNUSED SDLANCH...
