Block heater cord?
/ Block heater cord? #1
Black Acreage
John Deere 2155
Hi guys,
The photos say it all, but I've got a brand new block heater with a snapped power cord (1989 John Deere 2155). Was hoping to just plug and play with a new cord but the side that attaches to the block has a rubber weld and appears to be part of the unit.
Obviously I prefer not to replace the whole unit. Can this be fixed? How? Thanks guys.
/ Block heater cord? #2
You could use weatherproof butt connectors to connect to a new cord. You could then put shrink wrap over all the connectors.
/ Block heater cord? #5
Separate the wires and solder end to end so shrink wrap seals it good.
/ Block heater cord? #6
Easiest way would to just put a new cord end on the wires.
Or, you could try removing the lower cover and replacing the cord.
From Kat's heaters;
Another style of Kat's engine heater is a circulating coolant heater. This style is installed in a coolant line on your vehicle. It circulates the coolant through while heating it. Warmer engine coolant during cold weather will ease the stress on starts, gives heat to your cabin much faster, warms the oil faster, and leads to a longer life for your engine.
/ Block heater cord? #7
Splice a new cord onto the wires. Lots of different ways. Or, put a receptacle on the piece of cord that’s left.
Lots of different ways. All will work. Your choice.
/ Block heater cord? #9
As mentioned in previous posts just put a new end on. Cheap and easy
/ Block heater cord? #10
You’re probably already using an extension cord. Just put a plug on the new end of the heater cord and enjoy less excess cord in the off season. No splices.
The block heaters on both my tractors are like this. Never considered it would be done any other way. I put the extension cord on the short pigtail, that has a plug on the end.
A new cord end! That did it. Thanks guys.
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2012 Sun Coast Trailers 712ESB5 S/A Enclosed Trailer (A61569)
2012 Sun Coast...
2011 Jeep Wrangler Unlimited 4x4 (MPV), VIN # 1J4BA3H1XBL528743 (A61165)
2011 Jeep Wrangler...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
