Any landscape or utility trailers better than this one for the $?
   / Any landscape or utility trailers better than this one for the $? #51
The big thing with MOST single axle trailers is weight and length. My JD 2025r is a little less than 2000 pounds bare weight. I‘d haul that on a single axle trailer. Add loaded tire, FEL, ballast box, mid mount mower, it gets over 3000 pounds and is to long for most single axle trailers.
   / Any landscape or utility trailers better than this one for the $? #52
I had been wanting a car-hauler trailer for years. 7k 18 footers were generally around $2500 by me, for a long long time. Just when I secured the funds to go get one, covid hit, plans delayed, the trailers all disappeared. And when they came back available, prices had gone up at least a thousand dollars. I sorta knew I needed a 10k trailer too, or else I would be maxing out a 7k all the time and feeling nervous. The local 10k trailers went from low $3's to over $5k over this same time period, if you could even find one.
So when a like-new, used, package deal for my Kioti ck3510 came up that included a 20', 10k car hauler exactly like I wanted, well that sealed the deal, and I pounced. I received the original sales receipt for the 20' 10k hauler, and it showed a $4100 price back in 2019. Which I thought was actually a pretty good deal. Same trailer now is closer to 6 grand, ouch.
I don't seem to have a great pic of it.
   / Any landscape or utility trailers better than this one for the $? #53
the tundra doesnt seem any smaller then the other 1/2 tons
Driveline wise, it is. and that is where it counts. Domestic trucks have a much more robust driveline, but then no 1/2 ton truck works for me. If it's not at least a 3/4 ton, I'm not interested and far as RAM trucks go, their 3/4 ton trucks use coil springs on the rear axle and are inboard (inside the frame rails) mounted. I don't consider coil springs to be heavy duty rated at all. I want leaf springs out back and leaves in the front tooo, which negates IFS front suspension.
I have solid axles (Dana 60 front, Corporate 10.5 out back). Rides like a lumber wagon empty but loaded it's peachy.
   / Any landscape or utility trailers better than this one for the $? #54
When did Dodge go to rear coil springs? My 2007 2500 with 5.9 Cummins has leaf springs, and I also added a leaf to each side when I had a cab over camper. I thought just the 1500 has coil springs?
   / Any landscape or utility trailers better than this one for the $? #55
My neighbor is the general manager of a large Toyota dealership. He owns a Tacoma and a Dodge 2500. He has made the same comments you did about the Tundra, but he loves the Tacoma for hunting and off road use.
   / Any landscape or utility trailers better than this one for the $? #56
Couple years back.
   / Any landscape or utility trailers better than this one for the $? #57
Limited off road use. They don't have the ground clearance. Far as hunting goes, I walk in or ride in via horseback not drive. Vehicles tend to limit your chances of getting an animal. As a rule, horses or mules have plenty of ground clearance and they don't spook game either.
2002 Ford E-350 10ft. Box Truck (A55852)
2002 Ford E-350...
2017 Nissan Versa SV Sedan (A55853)
2017 Nissan Versa...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
JOHN DEERE 24" PIN ON EXCAVATOR BUCKET (A52707)
JOHN DEERE 24" PIN...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
